Yale GLP060VXEUSE087:
Brake shoe damage repeating
Having an issue on the right side brakes (dry brakes) where the brake shoe rests on the hold down pin is being forced into the pin bending the shoe up badly. Causing the wheel cylinder to leak fluid out resulting in loss of brakes. This is the left shoe on the right side. Brakes have been replaced I believe 2 times and this is the 3rd time this has happened. New park brake cables, wheel cylinders, hardware and shoes. Just curious if anyone has seen anything like this id like to fix this sob lol thanks for anyone that looks or inputs
  • Posted 9 Apr 2014 22:52
  • Discussion started by chris_v
Thanks ed t- I'll be looking for that the next time I see this issue.
  • Posted 23 Apr 2014 00:00
  • Reply by bbforks
sounds to me like a cracked backing plate allowing flexing.
use the eyeball closely between areas like the area where the wheel cylinder bolts up
  • Posted 13 Apr 2014 22:33
  • Reply by edward_t
sounds to me that it,s not built up correctly ,is the parkbrake bar in correctly with the spring in the right way round ??
  • Posted 13 Apr 2014 21:14
  • Reply by kevin_k
the shoe that is being damaged
is it the one where the cable hooks at the top, then wraps around a pin and cable sheave piece and then hooks to the adjuster at the bottom?
could it be the adjuster is getting out of adjustment causing the cable to pull the shoe out and bending it from the wrong angle of pressure being applied when it is out of alignment?
  • Posted 13 Apr 2014 16:18
  • Reply by swoop223
I recently had a glc50 do the same thing- a first for me. I did notice that the brake adjustment was way off prior to the brake rebuild. The symptom was weird- the brakes would lock as if the shoes were sticky-took brakes apart & brakes were dry but found the bent up shoes as you mention- I wrote it off as an adjustment issue- perhaps I was wrong?
  • Posted 13 Apr 2014 07:27
  • Reply by bbforks
edition #1234 - 12 June 2025
SMV (Konecranes) 16-1200C
Yale GDP100M
Flesherton, Ontario, Canada
