Bogging down slowly under load
I've got a truck that puzzels me. At least once every ignition cycle it will bogg down under any load ie; raising the mast, forward travel, sometimes revving it with park brake engaged. At the same time it'll smoke black out of the stack heavily. If I hold it there it'll smother out and die. If I let off (let it idle half a second) It'll run just like it's suppose to. Usually the rest of that Ig cycle. Thing is when I unplug the vacuum from the EGR it runs great, never misses a beat.
Things that have been done,
2000 hr PM(t-belt, all filters, etc.)
New EGR valve
Turbo(Preventitive due to unnecessary impeller slack, Intake hose off long period)
Updated turbo intake hose.
Any help greatly appreciated.
  • Posted 18 Dec 2007 10:50
  • By Mikisan
  • joined 18 Dec'07 - 1 message
  • Mississippi, United States
Life's not about the destination, It's about the journey. Mike.
Make sure the vacuum line is plugged in to the diaghram on top of the ECR and NOT on to the vacuum pot on the side of the EGR valve. If it is plugged in there it will close the flapper plate and choke off the engine. Also check the beginning of injection (will need laptop with Pathfinder) as if way too low engine will run retarded and bog down. Check vacuum to turbocharger with vacuum gun. Unplug vacuum line AT turbo and plug on to vacuum gun, start engine, MUST HAVE 18 to 20 inches of vacuum as soon as engine starts, if not check all vacuum hoses for leaks. IF SO, plug line and hook gun to turbo, apply 20 inches vacuum to turbo and test run by extending upright all the way up until it bottoms out - a good turbo and engine will maintain 2000 millibar of boost and 2800 rpm if everything in pathfinder is set at 100% - Hope this gets you in the right direction. Always check the turbo output as even a new one may not be performing correctly by nt letting the wastegate function correctly which is why you need to check the vacuum and manually apply vacuum to the wastgate control
  • Posted 20 Jul 2010 08:07
  • Modified 20 Jul 2010 08:12 by poster
  • By StarTrip55
  • joined 19 Feb'10 - 14 messages
(new belt) did you set the injection start time after?
  • Posted 3 Jul 2010 08:42
  • By fixit
  • joined 2 Dec'07 - 5 messages
  • bury, United Kingdom
Terberg RT223
UN Forklift FD30T-NJM1
October 13-15, 2026 - Shenzhen City, China
November 10-11, 2026 - Auckland, New Zealand
June 17, 2027 - Nottinghamshire, United Kingdom
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
Zhejiang UN Forklift Co., Ltd
