BELL HOUSING OVER-FILLS WITH HYDRAULIC OIL
ACTUALLY A MODEL H225E... A 1971 OR 1972 MODEL... GAS ENGINE... GMC 305 V-6... WET CLUTCH... MANUAL TRANSMISSION(S)... FOWARD-REVERSE BOX AND A 4-SPEED BOX.
THE BELL HOUSING OVER-FILLS WITH HYDRAULIC FLUID IMMEDIATELY UPON START-UP. WE OVERHAULED THE FLUID JET PUMP THAT'S MOUNTED ON THE SIDE OF THE BELL HOUSING THINKING THAT WOULD SOLVE THE ISSUE. HOW DO WE REGULATE THE LEVEL OF THE HYDRAULIC FLUID IN THE BELL HOUSING?
  • Posted 28 Feb 2017 12:09
  • By BAKER
  • joined 28 Feb'17 - 1 message
  • Colorado, United States
J.BAKER
It is correct to check the Jet pump out , but have you cleaned out the strainer - filter Part No 141787 ?. This is mounted on the right hand side of the bell housing , straining the clutch oil on its way back to the hydraulic tank. You should disconnect the hoses and remove it from the machine for cleaning. Not the easiest of jobs , but it would be restricting the flow back to tank.
  • Posted 3 Apr 2020 15:29
  • Modified 3 Apr 2020 15:37 by poster
  • By bagwan
  • joined 1 Sep'14 - 44 messages
  • South Australia, Australia
wags
we have a forklift with the same problem. what did you do to fix yours?
  • Posted 14 Feb 2020 02:21
  • By rod_naeve
  • joined 14 Feb'20 - 1 message
  • Iowa, United States
Not familiar with your exact model but the wet bell-housings I've serviced sometimes clog their drains, leading to an overfull condition. Have you checked yours?
  • Posted 4 Mar 2017 04:09
  • By bbforks
On the smaller trucks with the wet clutch, you could slide the oil tube to lower the output. I am not sure if the larger trucks had this feature.
  • Posted 3 Mar 2017 00:32
  • By BREWSKI
Taylor TT300
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Hawker Powersource, Inc.
Taylor TT300
USD1
Sue Tomic Sue Tomic
