Basic Charger H&C error AC
Hi all, the problem with the charger , the display writes an AC error, 380 Volt fits all-inclusive, if the machine is clamped manually, then the charger goes, there is no automatic start, where is the problem worth looking for? Thank you
Loader Hangcha , wires all without damage
  • Posted 22 Mar 2017 17:29
  • Discussion started by pavel_b
  • vao, Russia
Yes, it can be a major problem with the wirings or the fuse boards. The condition of the wires also matters a lot. So, you must consult electrical contractors bergen county NJ bloomfieldcooling.com for the professional help.
  • Posted 3 Sep 2019 20:19
  • Modified 3 Sep 2019 20:20 by poster
  • Reply by elaine_d
  • Louisiana, United States
Said, all right , thanks , burned the contact on the wire of the transformer
  • Posted 29 Mar 2017 22:21
  • Reply by pavel_b
  • vao, Russia
well it could be as simple as a bad circuit board but i have no idea on how to test it , best solution is to contact the manufacturer of the charger or local battery company where charger was purchased.
  • Posted 28 Mar 2017 23:35
  • Reply by swoop223
Thanks, checked again everything, everywhere all OK, maybe it does not work , switch time, before it all goes
  • Posted 28 Mar 2017 17:55
  • Reply by pavel_b
  • vao, Russia
saw the photos
looks like a standard charger
one question - did you remove the DC fuse from the neg power cable? or does it have a shunt in it? cannot see it clearly enough, looks like it has a small shunt.
anyway, problem is in AC circuit if it gives AC error so input AC voltage should be present at junction block where it comes into contactor on left.
If no AC voltage there then go back to breaker box on wall where charger hooks to and check buss there. (may need electrician to check this).
  • Posted 27 Mar 2017 21:38
  • Reply by swoop223
Yes, Sent , thanks for the help
  • Posted 25 Mar 2017 08:54
  • Reply by pavel_b
  • vao, Russia
Can you take some photos of this charger outside and inside and datatag and send them to my gmail? My gmail is in my signature.
  • Posted 23 Mar 2017 07:46
  • Modified 23 Mar 2017 07:47 by poster
  • Reply by swoop223
Charging in the same range 48v , recheck again all the contacts , thank you
  • Posted 23 Mar 2017 05:43
  • Reply by pavel_b
  • vao, Russia
Well the ac error indicates a power source failure of some kind
Isvoltage to charger correct?
If charger can be setup for multi range voltage source is it set to correct one?
The same as voltage supply?
  • Posted 23 Mar 2017 02:42
  • Reply by swoop223
The fuses are all integers, wires all over the place when the relay starts to click manually
  • Posted 22 Mar 2017 23:45
  • Reply by pavel_b
  • vao, Russia
check the buss fuses on power supply?
should be 3?
if 1 blows out error will occur
  • Posted 22 Mar 2017 22:44
  • Reply by swoop223
Error E21
  • Posted 22 Mar 2017 17:56
  • Reply by pavel_b
  • vao, Russia
Ottumwa, IA, United States
Harrisburg, SD, United States
Wentzville, MO, United States
