back fireing/stalling
Hoping someone can help me start to fix my FGC30 forklift. The darn thing backfires after high rev so loud sounds like a shot gun going off. It also will not idle. I'm not sure where to start with a Lp gas engine. Please help me get started.
  • Posted 25 Aug 2018 21:49
  • By OutdoorsDave
  • joined 25 Aug'18 - 2 messages
  • Maryland, United States
Dave Walker
thank you for the help I will let you both know how it goes.
  • Posted 28 Aug 2018 20:48
  • By OutdoorsDave
while your doing what mrfixit suggested also check intake and exhaust manifold gaskets for vac leaks or any vacuum lines that could be leaking.
If the backfiring is consistant then it may be a cracked dist cap or something up that alley but i wouldn't rule out a vac leak at one of the manifold gaskets.
if you have time pull a compression test after you check the valve adjustments. If any cylinders are low you could have a cracked exhaust valve.
  • Posted 26 Aug 2018 10:35
For loud backfiring, you can start by checking the distributor cap, rotor, and spark plug wires. Then you could check the valve adjustment clearances.
  • Posted 26 Aug 2018 05:17
Still GX10
Still GX10 2000
Poland
EUR950
Aichi RX07B
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
