B.T. ROLATRUC FAULT CODES C16 AND C22
Hi guys
got a b.t rolatruc a fellow engineer is having trouble with it at a site which needs a long induction to get into so my boss as ask me to advise the engineer. I have no idea what these fault codes mean and whether the machine is A.C or D.C.
all i know is the machine is a reach truck which moves in direction then stops and shows fault codes c16 and c22.
Model. RRB1/15
SNO. 432144AA/2002
any help would be great.
  • Posted 7 Oct 2012 04:32
  • By bing098
  • joined 2 Mar'12 - 40 messages
  • Kent, United Kingdom
Other places to check if the key barrel is ok are:
The 10 amp F60 fuse in the motor compartment.
The K10 main contactor - coil terminals come loose.
The silver A5 card under the armrest panel, the terminals get dirty - its worth disconnecting it & giving them a spray with contact cleaner & the connector plugs
On the frequency convertors under the armrest if the main fuses look slightly toasted this can cause issues but that normally throws CAN error codes.
Also where the wiring loom exits out at the top of the cab pillar can rub through / short out BUT this normally throws CAN errors which you havent mentioned - one to watch for in the future.
  • Posted 7 Oct 2012 19:45
  • By Forkingabout
  • england, United Kingdom
thanks forkingabout
will relay this info and let you know how he gets on.
  • Posted 7 Oct 2012 07:56
  • By bing098
Hi
It will be a Reflex AC
Battery been checked for loose / corroded cell straps etc?
C16 = Accelerator pedal activated / error at start up
C22 = Tilt joystick activated at start up
Also check the wires on the back of the keyswitch are not loose OR more likely the actual terminals on the key switch can come loose, if you can twist / turn the terminals on the back of the keyswitch it needs replacing.
What happens with this fault is as you drive the truck the faulty keyswitch briefly breaks the electrical supply to the main A5 card so the truck will stop & then goes through the start up sequence, as the accelerator pedal or a joystick is likely to being used at the time it will throw the error code.
Sometimes you will see the dash display briefly go off then come on again but you have to be quick to spot it.
I've replaced lots of faulty key barrels on older Reflex's.
  • Posted 7 Oct 2012 06:02
  • Modified 7 Oct 2012 06:04 by poster
  • By Forkingabout
Muncie, IN, United States
Deborah Baker Deborah Baker
UN Forklift FGL25T
UN Forklift FD25T-C2JM1
