ATF in Transhydraulic oil in GCX25 not shifting right now!
Hi I'm new here and need some help or guidance as I screwed up big time. Picked up the wrong gallon jug and dumped about 2 qts of atf in with the hydraulic oil. I realized it when I started it back up and it shifted funny, shut it right off, drained it and replaced the filter. After that seemed like it was going to be ok but now forward is strained like brakes are on and everything else including nuetral is reverse! I hope its something simple but..... help!
  • Posted 10 Jun 2010 06:58
  • By bobby_d
  • joined 10 Jun'10 - 3 messages
No, they're just cartridge valves. Remove the 3/4" retaining nut and then you slide the solenoid off. The valve is about 1-1/8". Just unscrew and remove. Only a small trickle of fluid should come out if any at all. I just had this same problem on one of my Daewoos and a C25C a month ago.
  • Posted 11 Jun 2010 06:47
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
I see the 2 valves under the plate on front. It is a model GCX25, the serial number is GX230-0154-7960KOF, looks like made in 7-91.
I will try the dis-connect idea first and then swap 'em if all else fails. Is anything going to fall down inside the case when you lossen them up? I may have time to do it this evening, I will post results if any, thanks for all the help guys!!
  • Posted 11 Jun 2010 06:37
  • By bobby_d
Sounds like a stuck solenoid valve to me. I think you'll find the valves on the front of the transmission, probably under a little 2 bolt cover. Otherwise they'll be on the right-front side of the tranny. First discannect both solenoids and then does it still get stuck in reverse? Try swapping the 2 valves and see if it's now stuck in forward
  • Posted 11 Jun 2010 05:45
  • By joe_d
What model is it? If it is one with electrical switches and solenoids that operate the transmission, then the switch assembly with the lever on it may have a broken piece in it causing it to go into reverse even though the lever is in neutral. Find the model on the ID plate.
  • Posted 11 Jun 2010 03:35
Hey and thats for the reply. It will on occasion work right, as in go into forward and neutral as it should. Is there not a shift solinoied or ? maybe at fault. I really don't know alot about it other than it went from working fine one minute to acting crazy the next.
  • Posted 10 Jun 2010 23:39
  • By bobby_d
good news - the oil you put in probably didn't cause this
bad news - sounds like the reverse clutch pack is warped/jammed.
Drain the trans oil and start it. If it wants to go backward still, even in neutral, then that proves the clutch pack has problems and trans must come out.
  • Posted 10 Jun 2010 09:44
edition #1285 - 11 June 2026
Mobicon 2T
Mitsubishi FGE35AT
