Anti-Stall code 524226-4
When this code is present is it normally just a bad anti-stall coil or are there typically other issues? Also where might this be located?
  • Posted 9 Apr 2025 22:11
  • By Zeeker
  • joined 9 Apr'25 - 2 messages
  • Arkansas, United States
Thanks!
Zeeker,
The anti-stall solenoid is not getting the correct voltage or is shorted internally. Using a VOM on ohms, check wire 702B against battery negative, should read infinity, anything else is a shorted wire. Check across the solenoid pin connections, should read 5 to 7 ohms. If you read lower, coil is shorted, higher coil has internal failure. Once you get the problem resolved, code will no longer show on the dash. Good Luck.
  • Posted 14 Apr 2025 22:39
  • By Fishmech
  • Virginia, United States
Rail King RK330
Aichi SR18A
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Lift Technologies Inc.
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
