Amber light flashes steady on display. Does not do steer pretes.t
I have a Crown, SP3400. When key turned on the display does nothing but the little amber light flashes steady. Lift does not go through test cycle. So far. The steer module has been swapped. Display swapped. The board has been replaced. The wire harnesses are good. Still lift will not start pretest. Any suggestions would be appreciated
  • Posted 25 Feb 2022 18:04
  • By Ward
  • joined 26 Jul'16 - 21 messages
C.Ward
Check the mast cables all of them one by one , check your brake pedal switch.
  • Posted 28 Feb 2022 20:50
  • By cubapnea
  • joined 3 Apr'13 - 24 messages
If it ain't broken...you know...
when amber light flashes are you sure there is no code the amber light should flash like a flash 2 times fast and say 4times slow this is called boot codes because the problem is happening before the self test. l know you replaced the dash and steering module but is any of the controller also have just the amber light on at the same time as dash also the dash you used was it programed for that truck. my self at onetime had the same problem but it was a loose pin connection at the dash display the one clip on the harness to connect to the dash was broke and was not making a good connection with a pin on back of dash. Check all connections real good.
  • Posted 28 Feb 2022 17:57
  • By Scott_
Scott
Big Joe PDR30-154
USD7,500
Terberg YT222
Big Joe PDR30-154
USD7,500
Terberg YT222
