alarm Logic Failure # 4 CAN Bus KO EPS hyster R1.6h
hi,
I have a problem with stacker.
The truck runs normally, but the alarm appears occasionally.
Wainting for traction - mod 06
Logic Fail # 4 - 02 mod
Logic Fail # 4 - 01 mod
CAN Bus KO EPS - mod 01
And turn off and on desappers alarms and operates normally.
Failure Alarm Logic # 4 for traction and CAN I / O module is not in the service manual.
And the coach has changed traction modules, CAN I / O and EPS for testing.
  • Posted 13 Mar 2012 11:02
  • Discussion started by hysterbrazil
  • rio de janeiro, Brazil
Showing items 1 - 15 of 20 results.
hello i have a problem with a HYSTER richtrack R1.4 my costumer put wrong the battary plug and now at my zapi tester shows (wrong set bat) (Logic failure) (CAN BUS KO) can help me what need to do?
ABP FORKLIFT / PITSIKOPOULOS GROUP
GREECE
I have the same problem with these trucks. Mod 6 Slave? If anyone knows i have checked manual but no help also the battery tray latch is always seizing up.
  • Posted 27 Oct 2016 02:11
  • Reply by luke_m
  • Bedfordshire, United Kingdom
Thank you all for your help:)
  • Posted 11 Oct 2016 18:55
  • Reply by zilvinas_n
  • Vilnius, Lithuania
ERROR CODE: 21534
Truck behaviour: traction enabled, hydraulics disabled
LED on DDI: red
Error code Type of failure Failure explanation Troubleshooting
21534 Horn failure The controller detects
that the circuit of the
horn coil is open
1. Switch off the key switch and switch it on
after few seconds and check if the same
error code is repeated
2. If it is, disconnect the battery
3. Disconnect the controller connector and
check the resistance between pin 20 on the
truck connector and the key switch
- If the resistance is higher than 50O
- replace the horn
- replace the wiring
Pasmotri mail daa
  • Posted 11 Oct 2016 00:09
  • Reply by geroj
  • Krivan, Slovakia
Hello, I have Hyster P2.0S C439X03604E and error Co21534. It is also didt lift.
Can you help me ? Also can someone share manual of this mashine (email zilvinas (dot) naudziunas (et) gmail (dot) com)?
Thanks in advance!
  • Posted 10 Oct 2016 20:55
16 CAN BUS KO VALVE check keyswitch and relative
connections
  • Posted 31 Oct 2014 02:35
  • Reply by geroj
  • Krivan, Slovakia
Hi,
I have a R1.6H 2003 model
Serial C435T02645A coming up with error
Alarm on mode 16 cam bus ko valve can anyone help?
Regards
  • Posted 30 Oct 2014 10:09
  • Reply by matthew_p
  • Victoria, Australia
Check the impedance Canbus.
Check the connection of components canbus
  • Posted 4 Sep 2014 14:59
  • Reply by geroj
  • Krivan, Slovakia
I have a problem The truck runs normally, but the alarm appears when happen vibration on truck or after 2 hours from work the truck shut down and screen show this message:
CAN BUS KO
S 247
NO CAN MSG N.03
P 247
NO CAN MSG N.02
And turn off and on disappears alarms and operates normally.
can you tell me how I can solve this problem?
  • Posted 4 Sep 2014 10:18
  • Modified 4 Sep 2014 10:24 by poster
  • Reply by rafed_a
  • SANA'A, Yemen
i have the same problem.
please, can you tell me how i can solve it ?
  • Posted 4 Sep 2014 09:50
  • Reply by rafed_a
  • SANA'A, Yemen
Friend!
the manuals are not available on free sites
Only authorized technicians may have access
I do not have this access
  • Posted 6 Sep 2012 09:55
  • Reply by hysterbrazil
that's it
great job, thanks a lot
can you please give me the link or the web site where to find pdf for the error code list ?
this will help me a lot
thanks again
  • Posted 5 Sep 2012 21:18
  • Reply by adil_h
  • settat, Morocco
21568-Main contactor
problem
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
21568 Main contactor
problem
that the main contactor
is not switched on
2. If it is, check the voltage drop across the
contacts of the main contactor
- if the voltage drop is higher than 2V,
replace the main contactor
3. Disconnect the battery
4. Check the fuse on the controller
- replace the fuse
5. Check the power wires that come to and
from the main contactor contacts
- replace the wires
6. Check if the wires are well tight on the main
contactor
- tighten the wires
7. Check if the wire from the main contactor is
well tight on the controller power terminal
B+
- tighten the wire
  • Posted 5 Sep 2012 10:03
The Serial Number = C439X02316D
thank you
  • Posted 4 Sep 2012 21:51
  • Reply by adil_h
  • settat, Morocco
which the serial number?
  • Posted 4 Sep 2012 07:20
edition #1235 - 19 June 2025
