Alarm 13 code
I have a Yale Pallet jack and the traction and hydraulic aren't working and I have checked the wires to the motor and battery is good.
  • Posted 17 Jul 2019 05:31
  • By Danger
  • joined 17 Jul'19 - 7 messages
  • Kansas, United States
You had the wrong model selected, should have been MPB040EN.
POSSIBLE CAUSES AND TEST PROCEDURES Cable connection to m*otor field is loose or damaged. Verify connection of field wires to motor and controller. Motor field winding* is shorted to chassis. Motor field should be less than 2 ohms. Verify battery conditi*on, charge, and connections. Failure of current sens*or in controller or failure of field current driver in controller. Replace controller. Check for resistanc*e between A1 and A2 to case, it should have approximately 0.5 mega ohms. Check for F1 and F2 n*ot to be open, and to have clean and tight connections. The resistance across F1 and F2 should be between 0.5 and 2.5 ohms
  • Posted 18 Jul 2019 03:56
  • Modified 18 Jul 2019 03:58 by poster
  • By BREWSKI
The serial # B82N18007C
  • Posted 18 Jul 2019 02:31
  • By Danger
Post the serial number so we can identify the controller type.
  • Posted 17 Jul 2019 06:50
  • By BREWSKI
JCB 533-105
Mitsubishi Logisnext FD25T5M
VETTER Industrie GmbH
