Air-conditioning
Hello.......I have a problem with the air conditioning..... Unfortunately I don't have a clue about it... It works but blows only heat......I don't have a circuit diagram........what should I check???....
Thanks
  • Posted 8 May 2020 19:54
  • By gr_defkalion
  • joined 25 Oct'19 - 11 messages
  • Greece
ath_syntiritis@yahoo.gr
Post the serial number for the truck you can't do anything to repair the air on unit yourself
  • Posted 24 Jun 2021 06:06
  • By lifter01
  • joined 4 Jul'09 - 465 messages
Linde H25D? I didn't hear about this model for a while. Air-conditioning for it? Hmm, I'd suggest you buy an aircon at the place you keep it. It would help a lot, I guess. When the air in the area you own it will be cold, you won't have any problems with this stuff. You should check http://airconservicing.org because recently I was looking for an air conditioner, and found that website. Let's hope that you won't have any more issues with your Linde and its options. Also, don't freeze the place. It can break something in the motor.
  • Posted 21 Jun 2021 22:59
  • Modified 23 Jun 2021 16:23 by poster
  • By MultingLava
  • joined 21 Jun'21 - 1 message
signature
Thank you very much for the reply......I found out that there was problem with the wire controlling the tension and the heat and cold.......
Is there any way to know where to check the liquid for the cold??
  • Posted 22 May 2020 16:28
  • By gr_defkalion
  • Greece
Serial number of the truck would help. They do have a habit of the cable coming off the back of the switch on the control panel I've Seen that lots. If not the unit might need re-charging
  • Posted 11 May 2020 04:42
  • By lifter01
Alogotransiphobia is the fear of being caught on public transport without a book to read.
edition #1294 - 13 August 2026
In this week’s Forkliftaction News, we report on Jungheinrich’s H1 financial results and the reasons it has adjusted down its EBIT forecast for the year... Continue reading
