Toyota 42-6FGU25:
4y engine dual fuel missing and stalling
We have a customer's Toyota 42-6FGU25, frame # 68662 equipped with a 4Y and a duel fuel ("convertible" in Toyota speak) that gives us diagnosis problems. It has approximately 8000 engine hours. When the operator drives across the yard at full speed, pedal to the metal so to speak, the truck will run fine for a short period of time then start to sputter and lose power and sometimes completely stall. If you shut down the machine for a few minutes it will start right up as if nothing was wrong. We know that the machine does this when the operating temperature is normal but we as yet do not know if it does it when the engine is "cold". We have done the obvious stuff, tune up with plugs wires cap and rotor. As well we installed a new regulator. We also have spent a lot of time on "adjustments" particularly on the dual fuel carb. Has anyone else experienced such a situation? I'm looking for advice on what the next thing we should look at. I have also posted the same question in the Mechanical discussion forum.
  • Posted 30 Jul 2011 00:30
  • Discussion started by chickenbone
Everyone has a friend in the forklift business!!
A bit late but, had this happen with a 4y on dual fuel before, we had to install a balance pipe from the air cleaner intake pipe (dirty side) to the atmosphere side on the LPG converter. It also sometimes happens when a snorkel is fitted to a LPG 4x4.
  • Posted 11 Dec 2020 17:59
  • Reply by AVav
  • New South Wales, Australia
I've had that issue when the the ignition system starts to fail. Install a timing light on any plug wire & check if the spark becomes erratic when the machine starts to act up.
  • Posted 9 Jan 2013 07:52
  • Reply by bbforks
4k hours is around the time a build up can occur in the inlet manifold. Eddy also has a point about the valve lifters, they do stick on the 4Y particularily if the engine oil is not changed to shedule, Lots of guys that don't know LPG engines just look at the oil color and say the oil is OK even if it is past its service time. Have you tried a compression test?..... hope that helps Scrid
  • Posted 9 Jan 2013 03:06
  • Reply by BobbyT
  • Wilts, United Kingdom
Hey Bobby I have a 4y in a Toyota with almost 4K hours on it.
It doesn't actually stall but will run crappy mid throttle. Have you seen the manifold cause that issue as well?
  • Posted 9 Jan 2013 01:26
  • Reply by Scrid
i'm with bobby, if it's not that, try replacing the lifters, their cheap and will cause that same problem at high rpm.
  • Posted 23 Sep 2011 16:12
  • Reply by eddy
  • Queensland, Australia
I have a 5FG with the same motor and mine is doing the same thing. Some days it runs ok, other days it runs like crap. I rebuilt the regulator and have taken the carb and gov. apart 2-3 times and cleaned it out every way possible. It was pretty clean. Its only got 4xxx hours on it. (1998)
I dont think its the valves, it wasnt a gradual issues, it just happened out of no where.
  • Posted 22 Sep 2011 13:56
  • Reply by YSRRider
Take the carb off, if you havn't allready, and check the inlet manifold, when the 4Y has done >4000 hrs it gets a build up of gunge on the hot spot inside the inlet manifold which restricts the flow, giving a lack of power symptom. Bobby
  • Posted 26 Aug 2011 22:35
  • Reply by BobbyT
pull the head get a valve job. the seats are recessed into the head.
  • Posted 30 Jul 2011 11:05
  • Reply by toyzilla
easier to ask forgiveness than to ask permission.
Linda Häkkilä Linda Häkkilä
edition #1228 - 1 May 2025
