30SP42TT drive unit roller bearings
Any suggestions on how to tell if these need to be replaced? No spec. in manual. Only instructions for changing. Thanks!
  • Posted 13 Aug 2015 05:14
  • By W_D_B
  • joined 13 Aug'15 - 3 messages
Thanks popeye! I purchased the roller bearings and compared new to old with dial calipers. I will be replacing at the same time as drive tire. The race also has the indentations in the race that you mentioned. Are there other components I should be checking that may have been affected by prolonged use under these conditions? Is the replacement procedure for the race just to drop out from the bottom and bolt in new? Anything I should be on the lookout for?
  • Posted 16 Aug 2015 03:28
  • By W_D_B
Small pry bar or big screw driver between roller and drive unit. To much movement and they need changed. You will also want to check for indentations in the race were the rollers normally ride when steering straight
  • Posted 15 Aug 2015 22:30
  • By popeye
Aichi SR10C1SM
Taylor TT300
USD98,500
Aichi SR10C1SM
Taylor TT300
USD98,500
