Toyota 7FBEU15:
3 wheel toyota error code 71-1,AC, AD-2, AD-4 and AD-6
the three big bolts to hold the real wheel were broken and the rotation sensor was damaged. i know that is for the code 71-1. i need help for the other code 'AC', 'AD-2' 'AD-4' and 'AD-6'. thanks.
liwan at juno dot com
  • Posted 13 Jun 2012 11:26
  • Discussion started by li_w
I just repair the AD-6 fault, caused first by loose and dirty fuse, coupled to the material control system, such a fuse because it is dirty and loose caused several faults in the forklift such as AD-5 (After failure AD- 6), the flow diagram to repair the fault says that you must look for false contacts, because the material control system is in trouble, for this you must first check the communication of the CN101 connector cards and CN111 connector
  • Posted 18 Feb 2018 14:51
  • Reply by jose_a
  • sonora, Mexico
i have a toyota 7FBEU15 showing error codes AD-1 and AD-2
  • Posted 13 Dec 2017 09:04
  • Reply by gevaughn_k
  • kingston, Jamaica
Have a look at the main contactor in the electrical panel in the back.
Remove the inspection covers & you will see it.
Ive changed a couple of these contactors on Traigo 48s over the years.
If you unscrew the contactor to remove it, make sure you don't loose the clear plastic insulator sheet mounted behind it.
Also check the blade fuses in the black fuse holders, ive had the terminals in the fuse holders on older / high hours Traigo 48 spread slightly causing odd electrical faults over bumps.
  • Posted 22 Nov 2016 05:37
  • Modified 22 Nov 2016 05:38 by poster
  • Reply by Forkingabout
  • england, United Kingdom
My forklift model 8FBMT20 showing error AD-2,AD-6,AD-1,AD-5,CB-5.Please help me to diagnose this error.
  • Posted 22 Nov 2016 03:46
  • Reply by johnson_j
  • MAHARASHTRA, India
Don't know about your diesel truck.
  • Posted 9 Jan 2013 09:55
  • Reply by li_w
have a Toyota 02-8FDF diesel error code 71-1. Advise where to look? I assume that this sensor inversion wheels. Sorry for the language I'm from Ukraine. Can you have a list of codes?
  • Posted 8 Jan 2013 23:57
  • Reply by gurin_i
  • Ukraine, Ukraine
All these error codes were due to the damage of the main controller (controller itself and some wires), which just above the real wheel. have to fix the broken wires and repair the main controller $300 cost.
'AC' - semiconductor switch abnormality
'AD-2' 'AD-4' - traveling AC driver to main controller communication abnormality
'AD-6' - material handling AC driver to main controller communication abnormality.
  • Posted 9 Oct 2012 12:21
  • Reply by li_w
Linda Häkkilä Linda Häkkilä
edition #1228 - 1 May 2025
Yale Lift Truck Technologies
