2 speed trans not shifting
1996 Yale glp080lfnsbe088 ser# d870271
It looks like the second speed solenoid has 12v all the time.I'm needing any info on what controls the shift. And is energized 1st or 2nd gear
My Yale books don't cover this 2 speed. Thanks for any help.
  • Posted 9 Oct 2014 05:58
  • By Spec
  • joined 9 Mar'13 - 4 messages
  • Washington, United States
The shifter on this truck only seems to have forward and reverse no other spots to shift to.
I'll open it up and look for sure.
  • Posted 9 Oct 2014 12:30
  • By Spec
YALE part number is the same for all three switches....it is part number 9208523-00
  • Posted 9 Oct 2014 12:17
  • By kevin_t
From what I can make out in what I have...which MIGHT not be the right info for your particular truck but worth checking........there are three single wire switches at the control handle for shifting,these switches are the grounds for the Solenoids...the brown/black wire on the harness side for FWD switch2 changes to red/white at the switch,when the handle is moved for second speed it opens the fwd one switch and closes the fwd2 switch....it looks like fwd 2 switch is the left most switch under the control handle,fwd1 is the middle and the right switch is reverse,check this switch to see if it is faulty....Hope this wasn't to confusing and helps??
  • Posted 9 Oct 2014 12:12
  • By kevin_t
Terberg RT403
Terberg RT403
