1960 Towmotor info
Hi,
I just acquired a 1960 Towmotor that runs fine other than needing the brakes re-done. There is no plate or tag on the forklift. How can I find info on changing the brake pad(s) if I don't have the plate info?
Thanks,
Neil
  • Posted 29 Apr 2007 06:10
  • By fallon416
  • joined 29 Apr'07 - 3 messages
At one point in time Towmotor stamped the serial number into the front frame crossmember plate up near the top. With the serial number any Cat forklift dealer can tell you the model number and capacity range. If you need to replace the master cylinder, the master cylinder casting should identify who Towmotor was purchasing the cylinder from. The manufacturer name should be cast into the side of the cylinder along with a number. Two common suppliers were Wagner and Bendix. Take the cylinder to your Cat forklift dealer or any good parts store and they should be able to find a cylinder that will work. You may have to adapt some fittings.
  • Posted 15 Jun 2007 03:08
  • By robert_f
  • joined 2 Oct'06 - 1 message
  • Oregon, United States
The motor is a 4 cylinder. Don't know what the capacity is the tag is missing. In any event I don't think the shoe(s) need replacing. When I pump the brake pedal they become hard and brake fluid is leaking out from underneath. I'll have a look after the rain stops and see where it is leaking from. If it is just a line or the master cylinder then that's easy enough to fix.
Neil
  • Posted 1 May 2007 04:06
  • By fallon416
I found a date 3/1963 stamped on the top of the engine.
Does anyone have any idea what models where available in 1963 from Towmotor. A link to a picture would also be helpful.
Neil
  • Posted 1 May 2007 01:38
  • By fallon416
SMV (Konecranes) 4632CC5
Hoist Liftruck P360-48
Zhejiang UN Forklift Co., Ltd
June 9-11, 2026 - Stuttgart, Germany
The term "Spring", referring to the season, originated in the 14th century as "Springing time", describing how plants "spring" or burst into life after winter. In the 16th century "Springing time" was shortened to just "spring" for the season of new growth.
Louisville, KY, United States
St. Louis, MO, United States
Johan Leveque Johan Leveque
Vice-chair, ALICE - (Alliance for Logistics Innovation through Collaboration in Europe)
Co-CEO, LIS Logistische Informationssysteme (LIS)
Regional sales manager, Battery Builders
SVP business solutions for the Americas, Dematic
