1202 Service Interval
Hi
Is there really no other way to reset this other than the latest LSG plug in?
  • Posted 5 Oct 2022 00:53
  • By matt_s
  • joined 2 May'08 - 31 messages
  • kent, United Kingdom
The 1202 is a Co pletely different beast from the 39x series pal and Linde won't release the software to their own engineers until they've been trained on it. The engine isn't the old common as muck vw lump but keep doing bits on it if you want but I can see a big bill coming up
  • Posted 31 Oct 2022 03:51
  • By lifter01
  • joined 4 Jul'09 - 465 messages
I enquired about a service interval mate, I'm sure the training required to reset it is intense but thank you for more constructive advice about what I should **** with!
  • Posted 23 Oct 2022 06:20
  • By matt_s
I'm fully aware of Linde costs and will say again if you've not got the software/training you shouldn't be dicking about with the 1202 it's a completely different beast from the 39x range and without LSG you 1can do very little to them
  • Posted 23 Oct 2022 06:05
  • By lifter01
Maybe you aren't familiar with Linde costs, regardless thank you for the kind advice.
  • Posted 23 Oct 2022 00:46
  • By matt_s
Pathfinder does not work with the 1202 you need LSG for later linde trucks and let's be honest here if you've not got it should you be dicking about with them
  • Posted 22 Oct 2022 20:13
  • Modified 22 Oct 2022 20:13 by poster
  • By lifter01
You can still buy pathfinder on AliExpress
Although the 1202 service base won't be on it you should be able to use a different service base to connect
  • Posted 20 Oct 2022 17:53
  • By Lindetechnz
  • joined 28 Apr'21 - 58 messages
  • New Zealand
Lindetechnz
No you need LSG to reset the service light and make any other changes to the truck
  • Posted 15 Oct 2022 06:28
  • By lifter01
