0 compression after cylinder head job
Hello
I have a 2.4 litre psi engine
On hyster s50ft,and did complete cylinder head job,removed and cleaned all the valves and seats, new valve seals,timing belt,balance belt.
So have 0 compression all cylinders!
The intake valves are all open after installing
Rocker shaft,the exhaust side appears loose!
Triple checked the timing marks ,all good!
Cleaned and primed the lifters per the engine manual!
Please help ! Stumped!
  • Posted 11 Dec 2022 06:00
  • By Pistolpeted
  • joined 15 Dec'18 - 34 messages
  • Connecticut, United States
thanks for telling us what happened
  • Posted 28 Dec 2022 01:21
  • By stillworkin
  • joined 2 Nov'18 - 96 messages
Hello thanks for the reply
So my shop tech mistakenly mixed the valves up when reinstalling them,
The valve dimensions are very similar
So the exhaust valves went into the intake seat causing all the valves to be open when we bolted the rocker down,
Had to remove the head to correct it!
Thought I seen everything!
Thanks and happy holidays
  • Posted 27 Dec 2022 02:13
  • By Pistolpeted
try seafoam
  • Posted 16 Dec 2022 03:06
  • By stillworkin
Hi there,
set cylinder at TDC on compression stroke and do a cylinder leak down test, I bet one of the valves would be open.
  • Posted 11 Dec 2022 20:50
  • By Paul_V
  • joined 11 Dec'22 - 1 message
  • New Zealand
Sue Tomic Sue Tomic
Toyota 02-8FD25
Terberg YT222
