Upgrade your forklifts to safe and efficient power with advanced lithium-ion batteries
- 20 Jan 2022 ( #1060 )
In the material handling industry, the requirements for safe operations have become a good front view. In logistics warehouses it is urgent to find more efficient solutions on the difficult issues of charging, ongoing expenditures, hard maintenance and potential pollution from lead-acid batteries.
RoyPow has specifically designed solutions to overcome these difficulties.
At present, not only can a superior power option from RoyPow increase your material handling productivity, but it can also be safer by using built-in multiple protections and software systems with remote monitoring, OTA (over the air), control panel and BMS (battery management system).
RoyPow's robust batteries have a 3 to 4 times longer lifetime than lead-acid batteries but can be recharged in a very short time, as well as having zero maintenance. Converting from lead-acid to lithium-ion is easy, cost effective and increases the productivity of the forklift and the operator, and we will give you a final shot with a 5-year warranty.
For higher productivity, put LiFePO4 in your forklifts
Lithium iron phosphate (LiFePO4) batteries have the advantages of high specific energy, light weight and long cycle life. Furthermore, the LiFePO4 batteries have greater thermal and chemical stability. By helping to extend battery lifespans and performance stability, investors will see improved revenues and returns.
In the context of day-to-day operations, RoyPow lithium-ion batteries can be charged even during short breaks, such as a coffee time or changing shifts; effectively increasing productivity. Whether you have a single-shift or a large fleet working 24/7, fast and opportunity charge can deliver you a hassle-free experience.
Remote monitoring & OTA allows the forklifts to speed up service response time
The specially designed 4G module can solve software problems in time and has GPS to lock the forklift if necessary, for the functions of remote software upgrading, remote monitoring and diagnosing.
The OTA (over the air) system can show all critical battery indexes, like voltage, current, remaining charging time and fault alarm. Once in the network system, the systems enable remote checking of vehicle systems, location, services meter readings, energy consumption, and idle time through a computer.
Furthermore, they can display some real-time abnormality codes on the display screen in order to speed up service response time.
BMS delivers the battery & forklift multiple built-in protections
The intelligent BMS (battery management system) automatically prevents over-discharge, charge, voltage and temperature, as well as virtually eliminating misuse.
What’s more, the system is equipped with a built-in equalization circuit, which can realize full time equalization. The batteries can be equalized as long as the BMS in effect, so that the battery can maintain long-term consistency and improve the service life of the battery.
The RoyPow intelligent battery range: 4 systems cover all kinds of applications
To adapt to the most forklift ranges, our batteries are generally divided into four systems: 24V, 36V, 48V, and 80V. They cover a full range of forklifts to allow for optimal performance. The intelligent batteries are even more compatible with our original charger: high service life and smooth performance.
For more information on intelligent battery solutions, contact us! Ask us about our references on RoyPow Intelligent Battery Solutions.
RoyPow (USA) Technology Co., Ltd.
Ph: (+1) 512 688 5555
(Business hours: central time (UTC-6 CST) 9 am-5 pm)
Email:  send an email
Web: www.roypowusa.com
California Office: 1267 Johnson Dr., City of Industry, CA91745
Florida Office: 3920 Anchuca Dr. #8, Lakeland, FL 33811
Texas Office: 107 Halmar Cove #131, Georgetown, TX 78628
Get in touch with ROYPOW
ROYPOW
+86 (0)... Show
ROYPOW Industrial Park,
No. 16, Dongsheng South Road, Chenjiang Street,
Zhongkai High-Tech District, Huizhou City,
Guangdong Province, China
ROYPOW
Briefs United States
