Ragasco Composite LPG cylinders for Fork Lift Trucks
- 2 Dec 2010 ( #490 )
Ragasco has supplied over 5 million Composite LPG cylinders worldwide since 2000 and in 2006 the company introduced their composite LPG cylinders for Forklift Trucks (FLT). The cylinders are available in two sizes 10 kg (22 lbs) and 14 kg (31 lbs).
The major advantage is the light weight. The largest cylinder has an ex valve tare weight of only 7.5 kg (16.5 lbs) giving a maximum weight of 21.5 kg (47.3 lbs) when full. European Manual Handling Operations Regulations state that you cannot lift anything heavier than 25 kg further than elbow height, so the Ragasco FLT cylinder is well below this requirement. All cylinders have identical tare weight and less weight equals reduced fuel cost.
The low weight combined with an ergonomic design makes the cylinder very easy to lift and handle. They are also stackable. The single-piece pressure vessel is a seamless construction for maximum safety. The all-composite cylinder is corrosion-free and has a clean inner liner surface assuring no contamination to the engine.
The FLT cylinders can be delivered with a wide range of colors and valves for liquid service including a US configured multifunction valve with service connector, pressure relief valve and stop-fill function for filling in the horizontal position. The valve is available in a UL listed version as well as TPED (Pi) marked version.
Lightweight, Transparent & Safe
Health and Safety
The unique lightweight composition offers enormous advantages for use by all parties, and in particular employees of gas companies will find lifting the tank much easier and safer. Reducing the weight by up to 50% compared with steel, and 25% compared to aluminum will make propane a more attractive fuel for Forklift Trucks.
Ragasco's cylinders have unrivalled safety in both short and long term, with no risk of explosion and no corrosion over time regardless of climate. Since the cylinders will not explode your insurance cost may be reduced.
The Ragasco composite LPG cylinders are approved in a number of countries throughout the world including the EU (ADR/ RID, TPED - Pi-mark), The US (DOT special permit) and Canada (Transport Canada).
Lower Operational Costs
The construction of the cylinder is non-corrosive therefore there is no need for sandblasting, scraping, painting and the associated labor cost. Simply Wash, Fill and Go. Easily portable and attractively designed, these are the LPG cylinders of the 21st century.
Customer Loyalty
Introduce the Ragasco composite FLT cylinders to your customers and they will never go back to metal cylinders. Be innovative and the first in your area with this unique product.
For more information visit Ragasco's website at www.ragasco.com or contact Ragasco at:
United States and Canada:
Bob Jones - North America Sales Manager
E-mail: bob@ragasco.com
Telephone: +1 561-254-8821
The rest of the world:
Morten Balle - Regional Sales Director
E-mail: mba@ragasco.com
Telephone: +34 699 924 048
Briefs United States
