Nichiyu Rack Forklift Trucks: total solution for more efficient use of space
- 1 Jul 2010 ( #468 )
Nichiyu rack forklift series can handle loads from three directions without turning. That means you need only 1,480 mm stacking aisle width - the same size of the truck itself - and the storage capacity is significantly increased compared with using standard warehouse forklifts which need stacking aisle wider than the truck length.
What's more, the total AC control for traveling and lifting, and electric turret head for shift-and-rotate functions offer exceptionally smooth and quiet operation with great energy efficiency. This reduces shaking of loads at high lifting position, allows safer and more accurate operation and increases operability in warehouse with medium-height racks.
Offering loading capacities from 500 to 1500 kg, and a maximum lifting height of 7.5 metres, the Nichiyu Rack Forklift truck is the solution for higher and more efficient use of space in your warehouse.
For further information please visit Nichiyu ShopFront.
