EP Introduces a New Electric Pallet Truck
- 10 Jun 2010 ( #465 )
In June 2010, EP engineers will unveil a new EPT-20RA electric pallet truck with the latest AC technology.
Appearance
  • Ergonomic design, with streamlined appearance and improved user comfort.
  • AC drive motor has no brushes, reducing maintenance and labour requirements.
Performance & Reliability
  • The innovative AC system offers quick response, accurate control, impact structure (doesn't make sense), excellent performance and longer battery service life.
  • Click to enlarge image
  • The high speed (8.0Km/h) design of EPT-20-20RA the guard arm in open position and stand-on platform in a working position enable the operator to work more efficiently in a ride-on mode. Normal speed (4Km/h) is available when guard arm is closed and stand-on platform in folded position in walkie mode.
  • World-class hydraulic power pack, with low noise, few vibration and excellent anit-leak tightness, automatically adjusts the rate of decline - whether loaded or unloaded, and ensures smooth lifting.
  • Dual robust lifting cylinders, connecting the right and left of truck frame with a synchronous con-rod, ensure stable lifting and lowering even under unbalance loading.
  • American top quality AMP connectors prevent moisture and contaminants from interrupting truck operatiosn in all environments. With all the wires and cables reliably protected and fixed, electrical error is greatly reduced.
  • The unique EASTPOWER suspension Driving Floating Adjustable (DFA) system design, reduces vibration, improves stability, and prevents tilting while turning at high speed, ensruing the accurate handling with a full load. Operating force of handle can be adjusted to suit various workplaces.
Operability
  • New tiller/handle head design for maximum operation comfortable, and control lift/lower/horn buttons positioned to allow operator with either hand.
  • Humanized guard arm design makes the guard arm open and close very easily to ensure the operator safe.
Safety
  • Unique arc board designed on the front frame ensures the clearance between front and rear frames stays constant, avoiding accidental clipping of hands.
  • Easy-Touch emergency plug mounted on the truck frame helps operators take immediate action in case of emergency.
  • Anti-skid braking system stops truck roll-back while traveling on ramps.
Serviceability
  • One-piece lightweight service access top cover conveniently bolts on and off for easy access to all major and key components, reducing service time.
  • Vertical motor ensures convenience inspection and maintenance of motor and brakes.
  • Self-Diagnostics provided through the digital display allows easy troubleshooting with the use of an external hand-held analyzer.
  • Hinged battery steel cover can be easily opened, enhancing top-up efficiency.
For more information, please visit www.ep-ep.com
Click here to view the EP shopfront
