New Compact Five Stage Mast Launched by Lift Technologies
- 3 Jun 2010 ( #464 )
Lift Technologies (USA) has just launched a new line of Compact Five Stage masts which has a unique compact mast rail configuration offering very good visibility, yet the mast can be configured for lift heights up to 331", with a collapsed height of 90". The cylinders and chains are nested behind the mast rails which provide a clear visibility window for the operator when placing and retrieving loads.
The new Five Stage mast can be equipped with an 8 roller integral carpet pole carriage for use in carpet and associated industries where load lengths can exceed 12'. The mast can also be ordered with a standard hook style carriage for applications where forks are required.
A unique feature about the design of Lift Technologies' new Five Stage mast is that it can be mounted on 6500, 7000 or 8000 lb. capacity lift trucks. Mast capacity ranges from 2750 lb. at a 72" load center which increases to 5000 lb. at a 24" load center. The compact rail stack design improves the lost load center significantly over traditional 5 stage mast designs, and also offers a reduction in weight compared to earlier versions.
Lift Technologies is a global leader in the design, assembly, manufacture and sale of masts, carriages, integral sideshifters and fork positioners for mobile materials handling equipment, with locations in Westminster, SC and at Elecar in Piacenza, Italy.
Lift Technologies, Inc.
7040 South Hwy 11, Westminster, SC 29693
www.lift-tekelecar.com
email:salesorders@lift-tekelecar.com
phone: +1 864-647-1119
