Integrated Fork Positioner With Extreme Stability type iFEXS
- 25 Mar 2010 ( #454 )
Integrated fork positioner with extreme high stability and residual capacity - designed with the truck drivers view very much in mind.
  • Extremely stable due to shaft transmission in the top and bottom
  • Tolerate side pressure on the forks
  • Precision and quiet operation
  • Unique total view
  • Suitable for harsh environments
  • Up to 8 tonnes
  • Many types of fork
Integrated Fork Positioner With Extreme Stability type iFEXS is a "pin-type", with accurate positioning of the forks, making it highly suitable for jobs focusing on precision and noiseless operation.
The dual shaft transmission in the top and bottom ensures stability and makes the unit tolerate pressure on the sides of the forks.
iFEXS provides an optimal view in all situations. A clear view mast and the fact that hoses, tubes and valves have been removed from the visual field result in both an unsurpassed view for the truck driver and high efficiency.
The models range from 1.8t to 8t in widths up to 1900mm and forks up to 2400mm.
With an integrated solution, larger residual capacity can be achieved compared to attached equipment. In many cases, this results in the need for a smaller truck.
For more information please see our website at www.e-l-m.com
