Taylor Introduces the TX-4030 Rigger Truck
- 18 Dec 2008 ( #391 )
4 min read
The TX-4030 Rigger truck is one of the latest additions to the TX Series at Taylor Machine Works. The 132-inch wheelbase TX-4030 has a rated capacity of 30,000 pounds at 36-inch load center. Designed and built specifically to lift any kind of heavy tooling used in factories, the TX-4030 also incorporates the innovative and performance-proven features of the TX Series introduced by Taylor in 2007.
The drive axle is heavy-duty planetary utilizing a hypoid ring gear and pinion. Power is provided by a Tier-certified 6-cylinder 160-horsepower electronic turbocharged, charge air after-cooled diesel. Completing the power train is a three-speed, fully reversing, modulated powershift transmission with inching and standard Automatic Powershift Control. The rugged chassis is all-welded frame with bolt- on counterweight. The hood slides on rollers and can be removed.
The TX-4030 incorporates the performance-proven features of the entire TX Series to enhance service accessibility, componetry performance, operator performance, and productivity. The all-welded steel chassis can stand up to the most demanding tasks.
Large capacity fuel and hydraulic tanks are integrated into the chassis. A rugged yet light-weight rolling engine hood, swing-away side doors, easily accessible battery box, easy hydraulic tank access, and tilting cab assure rapid and easy access for routine and special maintenance. The electrical junction box is conveniently mounted under the cab with reset breakers and sealed electrical connectors. All wiring is color and number coded.
The standard TICS (Taylor Integrated Control System) utilizes J1939 CANbus technology. As a result hard-wiring needs are reduced and access to controls and performance data has been significantly expanded. An instrument panel mounted control monitor replaces the analog gauges and meters with displays providing standard operating data. Many operational functions and capabilities are defined and adjusted through the TICS system. Information related to performance and maintenance needs, electronic diagnostic functions including fault code history, and built-in shutdown system for engine and transmission protection are additional resources available through TICS.
The standard tilting cab includes many ergonomically designed features to increase operator performance and operational ease thereby providing enhanced productivity. Interior room in the cab has been expanded. The standard adjustable vinyl air suspension seat can be readily positioned for maximum operator comfort. It can rotate (15 degrees left and 20 degrees right) and includes arm rests, an orange anti-cinch seat belt, and OPS (operator presence switch). The standard electric joystick control provides fingertip control for smooth, precise handling; joystick components can be serviced separately. The two cab doors include sliding glass panels. All glass is tinted, and front and rear windshield wipers are standard. The instrument panel on the T-shaped dash tilts down for access. Reset circuit breakers are used instead of fuses. The steering wheel tilts and the electric roll shift control and parking brake control are easily accessed.
The transmission is controlled through the standard APC (Automatic Powershift Control). The vast glass area and truck design ensure excellent visibility front and rear and to each side. The operator gains access to the cab on self-cleaning, anti-slip steps. Three point access- egress is standard.
The 3-stage telescopic direct lift mast is rugged. Mast has one center cylinder. Lowering control is pressure compensated and a manual emergency lowering valve system is standard. The heavy-duty carriage features side-thrust bearing and greaseable shielded main rollers. Pin mounted forks provide full width adjustment.
The hydraulic system features a newly designed main hydraulic valve with gear-type pumps and sectional control valves. Manual override controls are provided on hydraulic accessory sections. The innovative cooling system includes a three-section bolted radiator, four coolers, high performance 7-blade pusher fan, and engine-mounted sealed fan shroud for maximum air flow through the coolers.
The TX-4030 and the entire TX Series include the durability and dependability that have been Taylor traditions for more than 80 years. Through the Taylor world-wide dealer network and the Sudden Service, Inc. after-market parts and service operations, Taylor customers can be assured consistent and reliable support will be readily available to keep their Taylor fork lifts on the job providing the productivity needed for improved bottom-line performance during many years of service.
Additional information about the TX-4030 is available from Taylor Machine Works, Inc., 650 N Church Ave, Louisville, Mississippi 39339, 662-773-3421, www.taylorbigred.com, or any Taylor Machine Works dealer.
Click here to visit the Taylor Machine Works ShopFront
