Ask ROYPOW: Why Switch to Lithium-Ion Forklift Batteries? Which Applications Are Suitable?
- 7 Aug 2025 ( #1242 )
6 min read
As carbon-emission rules tighten and non-road engine standards grow more stringent worldwide, high-polluting internal combustion forklifts have become prime targets for environmental enforcement. Although lead-acid battery forklifts have solved the problem of exhaust emissions, the heavy metal pollution and resource waste caused by their waste batteries cannot be ignored. Against this backdrop, the increasingly mature lithium-ion forklift battery serves as a new solution.
Advantages of Lithium-ion Batteries for Forklifts
1. High Efficiency
The lithium-ion forklift battery demonstrates superior charge-discharge efficiency, typically exceeding 90%, significantly higher than lead-acid batteries. This ensures more stored electrical energy is effectively converted into operational power for forklifts, minimizing energy waste.
Unlike a lead-acid battery, which suffers from progressive power decline as it discharges, the lithium-ion batteries for forklifts deliver stable voltage output throughout the discharge cycle. Therefore, forklifts can sustain consistent lifting and movement performance even at lower charge levels.
2. Long Life
A lithium forklift battery typically has a much longer service life. Under normal use and maintenance conditions, its cycle life can be over 3500 times, while lead-acid batteries generally have less than 500 cycles[1]. This long life means that enterprises do not need to change the battery frequently, alleviating the trouble and cost caused by battery replacement.
3. Low-cost Operation
While lithium-ion batteries for forklifts require a higher initial investment compared to lead-acid batteries, they offer substantial cost savings over their lifespan:
  • They eliminate watering and equalization charging, slashing labor and maintenance costs.
  • Superior energy efficiency, combined with higher energy density, cuts electricity use and reduces charging frequency.
  • Most importantly, the extended service life, typically 3-5 times longer than lead-acid batteries, dramatically decreases replacement expenses over time.
4. Intelligent Management
A lithium forklift battery is usually equipped with an advanced BMS, which can monitor the battery's state of charge, voltage, current, temperature, and other parameters in real time.
Meanwhile, the BMS can also upload data to the management platform, permitting enterprise managers to grasp the battery usage in real time and facilitate fleet management.
Suitable Scenarios for Retrofitting Lithium-Ion Forklift Batteries
1. Warehouses with Multiple-Shift Operations
In warehouses operating multiple shifts, forklifts necessitate constant operation over extended periods. Traditional lead-acid batteries, due to their limited runtime, often necessitate multiple battery sets for rotation and dedicated charging areas.
In contrast, lithium-ion forklift batteries exhibit extended runtime and fast-charging capabilities, allowing for charging during work breaks without the need for battery replacement.
2. Cold Chain Storage
The low-temperature environments typical of cold storage facilities seriously impair lead-acid battery performance. In sub-zero conditions, lead-acid batteries experience substantial capacity reduction and diminished charge/discharge efficiency, often failing to meet normal forklift running requirements.
Lithium-ion batteries for forklifts showcase superior cold-weather performance, retaining both high capacity and stable power output even at temperatures as low as -20°C. This guarantees reliable forklift operation throughout cold chain logistics processes.
3. High-Intensity Work Environments
In demanding operational settings such as ports, logistics centers, and manufacturing facilities where forklifts undergo continuous heavy-duty operation, a lithium forklift battery brings critical advantages. Its rapid charging capability enables 80% capacity replenishment within 1-2 hours, achieving minimal operational downtime. The stable power output confirms that the forklift keeps consistent performance even under maximum load conditions, greatly lessening work interruptions while enhancing productivity.
4. Cleanroom Applications
For sterile environments in electronics, pharmaceutical, and food processing industries where contamination control is paramount, conventional lead-acid batteries pose contamination risks through acid fume emission during charging and operation. Lithium-ion forklift batteries eliminate this concern based on the acid-fume-free feature, maintaining the stringent purity standards.
Guidelines for Switching to Lithium-Ion Forklift Batteries
Retrofitting forklifts with lithium-ion batteries is a systematic project that requires careful planning and execution. Below is a detailed guide:
1. Assess Requirements
First, inventory the fleet, including the brand, model, and age of each forklift. Next, evaluate usage frequency, such as daily operating hours and weekly working days. Additionally, identify the working conditions, including indoor/outdoor use, load requirements, and ambient temperature. Based on these factors, prioritize retrofitting.
2. Estimate Energy Consumption
Calculate the energy consumption of each forklift based on load capacity, operating time, and travel speed. This can be derived from historical data or through on-site testing. Accurate energy consumption data is critical for selecting lithium-ion batteries with the appropriate capacity.
3. Choose a Reliable Supplier
When selecting a supplier, consider their reputation, product quality, technical expertise, and after-sales support. It is advisable to partner with suppliers experienced in forklift lithium-ion battery retrofitting and review their product certifications and customer case studies.
4. Test and Validate
After selecting the batteries and related components, conduct pilot tests on a small number of forklifts. Monitor battery performance, including charging time, runtime, power output, and temperature fluctuations. Additionally, verify that the retrofitted forklifts integrate properly with other equipment.
5. Train and Regularly Inspect
Once retrofitting is complete, train operators and maintenance personnel. Training should cover lithium-ion battery usage, charging procedures, safety precautions, and basic maintenance knowledge. Establish a structured maintenance program to conduct regular inspections and upkeep of the batteries and related systems.
Lithium-Ion Forklift Batteries from ROYPOW
At ROYPOW, we possess a comprehensive range of forklift batteries for sale, with voltage ranging from 24 volts to 80 volts, and a maximum of 350 volts.
Our batteries feature UL 2580 certifications across all voltage platforms for ultimate reliability, high-quality Grade A automotive-grade LiFePO4 cells from global top brands, intelligent BMS with multiple safety protections (e,g, overcharging, over-discharging, and over-temperature protection), as well as a smart 4G module for real-time remote monitoring and upgrades.
To ensure fire safety even in extreme working conditions, each ROYPOW lithium forklift battery is equipped with one or two forklift fire extinguishers inside, with the former intended for smaller voltage systems and the latter for larger ones. When the temperature reaches 177.8?, the extinguisher is triggered automatically upon receiving an electric starting signal or detecting an open flame. A thermal wire ignites, releasing an aerosol-generating agent. This agent decomposes into a chemical coolant for swift and effective firefighting. Moreover, all materials used in the fire extinguishing system are fireproof materials with a UL 94-V0 fire rating. This offers enhanced peace of mind for operators, fleet managers, and business owners, safeguarding assets, reducing downtime, enabling safer material handling, and lowering long-term operation costs.
Here are two of our perfect products:
36V Forklift Battery
Our 36V 690Ah LiFePO4 Forklift Battery presents an excellent user experience for your Class 2 forklifts, such as narrow aisle forklifts and high-rack stackers. Its stable discharge performance enables your fleet to easily navigate in narrow-aisle warehouses.
Additionally, this battery for a forklift can operate in freezing temperatures as severe as -4°F (-20°C). With the optional self-heating function, the battery can heat up from -4°F to 41°F within an hour.
48V Forklift Battery
48V 560Ah LiFePO4 Forklift Battery is one of our 48V-system batteries, designed to provide a high-quality and safe power supply for your material handling equipment. This 560Ah has passed UL 2580 certification and holds an outstanding return on investment as it can continuously save on labor, maintenance, energy, equipment, and downtime costs.
Additionally, to meet demanding applications such as high-temperature, low-temperature, or explosive environments, we have designed air-cooled batteries, cold storage batteries, and explosion-proof batteries for premium safety and performance in extreme conditions.
Conclusion
With industries worldwide facing stricter environmental regulations and operational demands, the transition to lithium-ion forklift batteries represents more than just an equipment upgrade; it’s a strategic investment in efficiency, sustainability, and long-term cost savings.
As a reliable supplier, we stand ready with high-performance lithium-ion forklift battery solutions, along with complete technical guidance and support through every step of the retrofitting process.
For more information, please get in touch.
Reference
[1]. Available at: https://en.wikipedia.org/wiki/Lead%E2%80%93acid_battery
Get in touch with ROYPOW
ROYPOW
+86 (0)... Show
ROYPOW Industrial Park,
No. 16, Dongsheng South Road, Chenjiang Street,
Zhongkai High-Tech District, Huizhou City,
Guangdong Province, China
ROYPOW
