Bolzoni Group sets new standards with innovative solutions at LogiMAT 2025
- 13 Mar 2025 ( #1221 )
5 min read
BOLZONI Group, manufacturer of forklift truck attachments, lift tables and forks, is proud to announce its participation to the LogiMAT 2025 at Stuttgart Trade Fair Centre, in Germany, 11-13 March, 2025, in Hall 10, Stand C67.
This year, BOLZONI Group is unveiling a variety of exciting novelties and advanced technologies, including a range of electric-driven forklift attachments, new products, and several cutting-edge innovations.
With special focus on paper and recycling, food and beverage and white goods handling industries, we invite you to visit us at Booth C67 in Hall 10 to explore our wide array of material handling solutions.
World Release – NEW AURAMO 180° Paper Roll Clamp Range
Series AR-C model range is designed to meet the requirements of current and future roll handling. Auramo series AR-C paper roll clamps are easy and fast to use, require
less operator effort and have a smooth, slim design with superior visibility.
Series AR-C model range is designed to meet the requirements of current and future roll handling. Auramo series AR-C paper roll clamps are easy and fast to use, require less operator effort and have a smooth, slim design with superior visibility.
The well-proven AURAMO 180º rotating paper roll clamp just got even better now: discover the new optimized and even more service-friendly design with various modular driver assistance and support systems.
AURAMO HTX – The New Automatic Clamp Force System for damage-free paper handling
Say goodbye to paper roll damage with the HTX system! This cutting-edge, user-friendly solution is electrically controlled, making it effortlessly adjustable and configurable to accommodate varying load weights.
Specifically designed for paper roll manufacturers, transport companies, 3PL providers, and port operators, HTX offers an intuitive and straightforward way for lift truck operators to manage paper roll in diverse operational scenarios.
With HTX, you can significantly reduce possible load damage caused by excessive clamping force. Its advanced electrical control ensures seamless adjustments to match the specific weight requirements of each load, enhancing both safety and efficiency.
The NEW 4/2 Multiple Pallet Handler – Optimum Total Cost of Ownership and operator Productivity
The new 4/2 Pallet Handler is completing the MEYER G Series, featuring the only Multiple Pallet Handler range with a fully encapsulated shaft guide concept and modular permanent lubrication system.
The new G Series excels through a minimum of maintenance requirements, largely extended service intervals and long-life wear components for an optimum productivity and TCO.
The remote monitoring function includes also a remote diagnosis dashboard that allows to immediately intervene on the clamp set up and have a detailed view of the clamp's parameters.
Experience the Future of Warehouse Management with easy-MOVE 4.0
Bolzoni Group has the pleasure to unveil its latest innovation in white goods handling: discover the new, integrated warehouse management and remote-control system designed for damage-free handling of white goods and appliances in manufacturing and 3PL logistics. Our Product Specialists will be at LogiMAT to present this innovative system, featuring WIFI set-up control, remote diagnostics, and live reporting.
easy-MOVE 4.0 is a WIFI-connected, fully automatic electronic clamping pressure control system that ensures damage-free handling in white goods logistics. It adjusts the clamping pressure based on the detected load between the arms. Unlike competitors, easy-MOVE 4.0 also offers advanced light signal driving assistance technology, enabling even the most inexperienced truck drivers to handle washing machines, refrigerators, ovens, dishwashers, and other consumer products without damage.
AGV Solutions – Electric and Rotating Carton Clamp
As attachments specialist for AGV solutions, BOLZONI is presenting a solution engineered to enhance operational efficiency in automated logistics processes.
This electric driven rotating carton clamp is part of the AGV attachments range. With all sensors and wiring already included in the supply, the attachment is ready to be fitted on the AGV and to run. Wide attachment range already available, both hydraulic and electric driven, with specific sensors controlled and managed directly by the AGV monitor.
The NEW AM High Performance Integrated Fork Positioner with easy-FORKS and easy-LIGHT
Over 1,000 hours of maintenance-free use, minimal lubricant need, and an eco-friendly design that keeps your loads clean.
The new AM series expands the successful MEYER High Performance fork positioners range with a mast-integrated variant, designed for ultimate durability and efficiency.
With its encapsulated shaft-guided system and long-life bushings, it ensures smooth, low-maintenance operation, providing an optimum total cost of ownership (TCO) and a highly flexible solution, ideal for retrofitting, such as for rental fleets. Built to withstand the toughest conditions, it features easily replaceable shafts and a hydraulic system that reduces force for enhanced performance.
The AM model is versatile, compatible with various forks, and easy to retrofit. Its valve-free operation guarantees perfect synchronism, making it a reliable choice for modern lift truck operations.
Within the exhibit on stand 10C67 you find our Intelligent Products of the easy-Connect range: easy-FORK Vision Systems.
Our range of intelligent forks: fitted with cameras, laser beams and led stripes to improve safety and productivity granting for better visibility from the driver seat.
Enhancing sustainability and productivity with Bolzoni lift tables
Bolzoni Green Line 1E-Rot lift table thanks to the manual circular turntable improves ergonomics of the operations.
At LogiMAT 2025 we exhibit two of the highlighted products within the Green Line lift table range: the Manual Circular Turntable Lift Table and the 1E lift table.
Focused on environmental sustainability and ergonomics, the Bolzoni 1E rot model offers numerous integrated solutions to improve safety and operation efficiency. It makes handling and assembling operations easier.
The load is accessible without having to reach out or to walk around the table. It features an eco-friendly design, making it particularly suitable for assembly lines. The circular turntable integrated into the platform provides 360-degree rotation of the load in both directions, making handling efficient and safe.
The 1E model lift table is the best option as "workstation" to provide improved ergonomic conditions to ensure the health, safety and comfort of the operator together with improved productivity.
Don’t miss the opportunity to see our innovative solutions in action.
Visit Bolzoni Group at Hall 10, booth C67.
Our team of experts will be on hand to demonstrate how our products can transform your material handling operations.
For more information on our products visit our website, get in touch with Bolzoni Group, or contact the nearest BOLZONI, AURAMO and MEYER representative.
Bolzoni, Auramo and Meyer are Bolzoni Group brands.
The Bolzoni Group is a market leader in the production of forklift truck attachments, forks and lift tables. The company has manufacturing plants in Italy, Germany, Finland, America and China and through its network of direct branches and independent dealers covering all continents it is able to satisfy all market requirements.
Bolzoni SpA (Group HQ)
+39 052... Show
Via I Maggio, 103
I-29027 Casoni di Podenzano,
PC, Italy
