NOBLELIFT North America Set to Unveil New Products at ProMat 2025
- 13 Feb 2025 ( #1217 )
7 min read
NOBLELIFT North America, a global leader in Li-ion technology, is set to unveil new products at ProMat 2025, March 17-20, held at McCormick Place, Chicago, IL. Attendees at ProMat 2025 are invited to visit the NOBLELIFT booth, booth number S3531, to experience firsthand the cutting-edge features of these new products.
Along with feature-rich innovation, NOBLELIFT is known for manufacturing high-quality Li-ion (Lithium) powered material handling products that sell for the same price that other manufactures offer lead-acid powered products. NOBLELIFT makes it easy for you to achieve a superior level of electrification that lasts 2 to 3 times longer, allowing you to save time and money while improving your productivity.
Alongside the Li-ion powered products, NOBLELIFT will also be featuring high-performance, low-maintenance lead-acid powered and internal combustion powered equipment.
NOBLELIFT representatives will be available to provide detailed information, answer questions, and discuss how these products improve your material handling operations while lowering your overall costs.
Here are just a few of the NOBLELIFT models you can expect to see at ProMat 2025.
OPH26 / OPH26K Li-ion Man-Up Order Picker
The OPH26 / OPH26K Li-ion Man-Up Order Pickers operate within a 64” aisle width, have a 2,600 lbs lift capacity and are engineered to deliver exceptional versatility, easy handling and very low maintenance. With a wide range of capabilities, these order pickers can adapt to a variety of warehouse, manufacturing, distribution and food storage environments. They are designed to help run a faster, more efficient operation.
Available in lift heights ranging from 177” to 413”, they offer high-speed lifting and lowering and are equipped with a lithium battery capable of multiple shift operation. AC Drive and AC Lift motors contribute to smoother operation, greater energy efficiency and longer component life. High-maneuverability and high-reach capabilities make these order pickers the ideal choice for your most demanding applications where efficient, narrow aisle, high-lift height material handling is required.
CBT33 Li-ion Stand-Up Counterbalance Forklift
The CBT33 3,300 lbs capacity Li-ion Stand-Up Counterbalance Forklifts are designed for indoor applications where the operator needs to get on and off the vehicle frequently. Engineered for reliability and performance, these forklifts offer exceptional visibility, ensuring precision and safety in a variety of applications from loading trailers to navigating through busy warehouse aisles.
They offer lift heights from 157” to 276”, a small turning radius of 55.4” and are equipped with dual independent AC drive motors with separate drive controllers that provide superior driving. Capable of multiple shift operation.
RT33SP / RT44SP / RT33DP Li-ion Single & Double Scissor Stand-Up Pantograph Reach Truck
The RT33SP / RT44SP / RT33DP Li-ion Single & Double Scissor Stand-Up Pantograph Reach Trucks operate within a narrow aisle ranging from 72” to 76”. The RT33SP / RT33DP have a 3,300 lbs lift capacity and the RT44SP has a 4,400 lbs lift capacity. The RT33SP / RT44SP have a fork reaching distance of 22.4” and the RT33DP has a fork reaching distance of 41.7”.  They are engineered to deliver exceptional versatility, easy handling and very low maintenance. With a wide range of capabilities, these reach trucks can adapt to a variety of warehouse, manufacturing, distribution and food storage environments. They are designed to help run a faster, more efficient operation.
Available in lift heights ranging from 177” to 453”, they offer high-speed lifting and lowering and are equipped with a lithium battery capable of multiple shift operation. High-maneuverability and high-reach capabilities make these reach trucks the ideal choice for your most demanding applications where efficient, narrow aisle, high-lift height material handling is required. Capable of multiple shift operation.
FE3C32 / C35 / C40 3-Wheel Cushion & the FE4C50 / C65 4-Wheel Cushion Li-ion Forklifts
The FE3C32 / C35 / C40 3-Wheel cushion tire (3,200 lbs, 3,500 lbs 4,000 lbs capacity) and the FE4C50 / C65 cushion tire (5,000 to 6,500lb capacity) Li-ion forklifts are highly efficient, durable forklifts. They are designed for indoor warehouse applications and other applications with hard smooth floors. The mast system, front/rear axles and chassis are engineered to be tough like an Internal Combustion forklift, but with all the advantages of Lithium. AC drive technology is used to achieve ultra-smooth, high performance with low operating and maintenance costs.
The 3-wheel forklifts offer a smaller turning radius of 62” to 67” and excel at navigating within confined spaces. The 4-wheel forklifts have a large 80-volt Li-ion battery and regenerative braking system that significantly increases operating hours per charge.
FE4P50Q 4-Wheel Li-ion Solid Pneumatic Tire Forklift
The FE4P50Q-70Q Series are highly efficient, low maintenance, ultra-smooth, durable, Li-ion forklifts. They are designed for high-productivity indoor and outdoor applications. The mast system, front/rear axles and chassis are engineered to be tough like an Internal Combustion forklift, but with all the advantages of Lithium. AC drive technology is used to achieve high performance with low operating and maintenance costs.
FE4P130N-175N Heavy Duty Li-ion Forklifts
The FE4P130N-175N Series 13,000 - 17,500 lbs capacity Heavy Duty Li-ion Forklifts are designed for heavy lifting and work well for indoor and outdoor applications. They are structurally engineered to be tough like an internal combustion forklift, but with all the advantages of lithium. AC drive technology is used to achieve high performance with low operating and maintenance costs. Ideal for your most demanding applications: metallurgy, ports, container yards, automotive, mold manufacturing, paper roll handling, lumber yards, brick and stone distribution centers.
Equipped with a powerful 96-volt lithium battery capable of multiple shift operation, these forklifts come fully loaded with many extras as “standard”, including a back-up monitor, coupled with the AI pedestrian detection system.
SWB-280S Li-ion Walkie Straddle Stacker
The SWB-280S Li-ion Walkie Straddle Stackers, capable of 2,800 lbs. load capacities, are economical, quiet, very low maintenance, ultra-smooth, and are perfect for light and medium duty material handling. They offer Full Free Lift heights from 51.2" to 70.9" and lifting heights from 100" to 138". Their compact design, small turning radius and full free lifting mast makes them ideal for supermarkets, internal workshops, loading docks, narrow aisles, and applications within confined spaces like retail stores, trailers, containers, and warehouses.
SC Series Self-propelled Li-ion Scissor Lifts
SC Series Li-ion Scissor Lifts have a compact footprint and are designed for optimal performance, increased productivity and ease of maintenance. Operators can drive, steer and lift directly from the platform, at any height, to achieve continuous operation. These scissor lifts offer load capacities of 500 to 700 lbs and maximum working heights from 19 to 39 feet. Built-in extension platforms provide a larger working area and allow operators to work over obstacles. Work quieter and safer with NOBLELIFT indoor/outdoor, zero-emission, low maintenance scissor lifts.
PTE33N & PTE45N EDGE ELITE Li-ion Powered Pallet Jack
The PTE33N (EDGE ELITE 33) 3,300 lbs capacity and the PTE45N (EDGE ELITE 45) 4,500 lbs capacity, Li-ion electric pallet trucks are economical, quiet, very low maintenance, ultra-smooth, and are perfect for light and medium duty material handling. Their extremely compact design and turning radius makes them ideal for loading docks, delivery operations, narrow aisles, and applications within confined spaces like retail stores, business centers, elevators, trailers, containers, and mezzanines warehouses.
FD4RT50-70 Series 4WD Diesel Rough Terrain Forklift & the FTH50-60N Series 4WD Diesel Telehandler
The FD4RT Series 4WD 5,000 to 7,000lb capacity pneumatic forklifts and the FTH Series 4WD 5,000lb to 6,000lb capacity Telehandlers are highly efficient, durable, and diesel powered. They move high volumes and big loads reliably through the toughest terrain. The front/rear axles, chassis and overhead guard are engineered for extreme conditions.
The telehandler’s telescopic boom can extend forwards and upwards away from the vehicle to reach over obstacles.
(3) Telehandler Models:
  1. FTH50N-197 - 5,000lb capacity, forward reach 114”
  2. FTH50N-236 - 5,000lb capacity, forward reach 236”
  3. FTH60N-177 - 6,000lb capacity, forward reach 177”
Applications can include forestry, disturbed surface construction sites, oil refineries, military, waste disposal and agriculture. These high performance, low maintenance forklifts/telehandlers deliver improved productivity while ensuring operator comfort throughout the entire shift.
Take the first step and stop by NOBLELIFT booth #S3531 at ProMat. We are Noble. Expect More!
About Noblelift
NOBLELIFT® North America is a global leader in Li-ion technology. We manufacture a comprehensive range of high-performance, low-maintenance manual, electric, and internal combustion equipment with more than 200 categories and around 30 series of each product. Our products are designed to meet different application demands and are well accepted by our customers in more than 100 countries and regions in Europe, America, Asia, Africa and more. Products include: sit-down forklifts, rough terrain forklifts, narrow aisle forklifts, walkie-stackers, order pickers, electric pallet trucks, scissor lifts, tuggers/tow tractors, scrubbers, sweepers, automated guided vehicles (AGV’s), lift tables, manual pallet jacks and more. Noblelift® North America builds tough, durable products that deliver high productivity, low total cost of ownership, easy serviceability, and advanced ergonomic features; accompanied by outstanding parts, service, and training support.
For more information about our company and our products, visit www.nobleliftna.com or follow us on social media.
Get in touch with Noblelift
Noblelift
+1 847-... Show
2475 South Wolf Rd,
Des Plaines,
IL 60018
USA
Noblelift
As part of Forkliftaction’s 25th anniversary celebrations, we have dug into the archive and, over the next year, will be highlighting a carefully curated selection of historical stories we have published over this time... Continue reading
IMHX to become a biennial event Birmingham, United Kingdom
October 8-9, 2025 - Twickenham, United Kingdom
The origin of "love" as the score zero in tennis is debated, but two main theories prevail. One suggests it's derived from the French word "l'oeuf" (egg) which resembles the shape of the number zero. The other proposes it's related to the Dutch word "lof" meaning "honour" as players might be playing for honour when scoreless.
