Graphic and textual information of port machinery telehandler
- 7 Sep 2023 ( #1144 )
4 min read
XCMG Port Machinery telehandler
I.  Introduction:
Versatile functions, flexible mobility, comfortable operation, safe and reliable, energy-saving and efficient. Telescopic fork lift is a multifunctional equipment equipped with telescopic boom, fork or accessories, which is usually installed on the boom and can lift different goods. With excellent off-road performance, it can stretch and drive with load, and achieve multi-function expansion by combining different accessories.
(1) Lifting Type Telehandler:
Chassis type
Multi-functional off-road chassis,4WD transmission(front4/rear3), 4WS, Multi mode steering (front axle/crab/Circle), four wheel wet braking, frame turnover ± 10 °.
Working performance
Lifting height: 10m/14m/17m(2/3/4-section telescopic arms)
Rated load: 5t/5.5t/6.5t/8t(Center load distance600mm)
Driving performance
No-load: 32km/h, Gradeability>50%
Heavy-load: 25km/h, Gradeability>45%
Applicable scenarios
It is widely used in construction, agriculture, and industrial and mining enterprises for material handling, transport, and installation, taking into account the operating range and lifting performance, as well as the operation in all road conditions.
(2) City type Telehandler
Chassis type
Industrial chassis, mechanical box front axle drive (front 2/rear 2), rear wheel steering, front axle wet braking.
Working performance
Lifting height:  17m (4-section telescopic arms)/10m (2-section telescopic arms)
Rated load:  5.5t, 8t (Center load distance600mm)
Driving performance
No-load: 25km/h, Gradeability>28%
Heavy-load: 20km/h, Gradeability>22%
Loading, unloading, handling, and installation of goods in relatively flat workplaces, it has a wide range of operations and applications, with relatively low procurement and maintenance costs.
(3)  Rotation telehandler
Chassis type
Multifunctional off-road chassis, hydrostatic 4WD (front 2/rear 2), 4WS, multi-mode steering (front axle/crab/Circle), four-wheel wet braking, frame rollover ± 10 °.
Working performance
Lifting height: 21-25m (4-section hexagonal telescopic arm)
Rated load: 4.5t, 6t, 7t (Center load distance600mm)
Driving performance
No-load: 40km/h, Gradeability>42%
Heavy-load: 32km/h, Gradeability>38%
Taking into account the alternative application of comprehensive working conditions of cranes and climbing platforms, can construct under complex installation conditions, combined with multi-functional accessories to promote technique and safety improvement.
(4) Heavy-load Telehandler
Chassis type
Multifunctional off-road chassis, hydrostatic 4WD (front 2/rear 2), 4WS, front axle/Crab/Circle, four-wheel wet braking, frame rollover ± 10 °.
Working performance
Lifting height: 10m (2-section telescopic arm)
Rated load: 12t, 15t, 23t (Center load distance 600mm)
Driving performance
No-load: 28km/h, Gradeability>40%
Heavy-load: 22km/h, Gradeability>28%
Loading, unloading, handling, and installation of large goods in the entire road condition workplace, with strong working performance, expanded functions, and a wide range of applications.
II. Leading technology, safe and reliable
(1) Excellent off-road trafficability and field adaptability
Lifting, rotation, and heavy-load types are equipped with high-performance off-road chassis, which has excellent driving and field adaptability, making it easy to achieve all-road driving operations.
(2) High strength steel bending butt welding main arm, Less welding seams, high performance, and longer service life
(3) Multifunctional meter, integrated 7-inch display screen, more complete information and convenient exchange
Intelligent meter, zoning display, comfort viewing;
7-inch LCD screen for real-time display and monitoring of vehicle operation status;
Interactive control facilitates troubleshooting and parameter adjustment.
(4) Intelligent performance meter, dynamically displaying operation status, ensuring operation safety
Real-time display of Fork position, boom angle, operating range, operating height, and lifting capacity, providing intuitive data and safer operation
In order to fit the user's habits, the lifting type product also retains the instructions on the boom for old product users.
(5) CAN bus power management system, real-time monitoring of the status of each circuit, convenient maintenance, no need for maintenance
Real time monitoring the voltage and current status of each circuit, and can be viewed through the display
Self-diagnosis, automatic error reporting, convenient for troubleshooting
Automatic connection after line restoration, shortening maintenance cycle
III. Flexible and multi-functional
XCMG standardized accessory interface, seamless and fast switching of multiple accessories, on-demand configuration, high attendance rate, and low maintenance cost.
IV.  XCMG Electric telehandler
XTF18010E Introduction
Vehicle type
Two axle chassis(4WD, multimode steering,front?rear axle Maximum static load 60t)
Endurance
8.7hours (282kwh Lithium iron phosphate battery, ensure adequate battery life)
Rated capacity
18t (Center load distance 600mm, the standard configuration of lifting height is 9m)
Speed
No-load: 30km/h
Heavy-load: 25km/h
(1) Excellent off-road performance
Dual motor 4WD technology, full load gradeability 35%?
Four wheel steering: three modes, Min steering radius 4.8m.
Vehicle body leveling: ± 10 ° turnover to meet different operating conditions.
(2) Comfortable operation
The constant power load sensing pump cooperates with the electric proportional valve to compensate for the load sensing valve, providing accurate flow distribution and stable composite action.
Multifunctional integrated handle, fully suspended seat, panoramic cab, high-power heating and cooling air conditioning, comfortable to work.
(3) Safe and reliable, convenient for maintenance
High precision load moment indicator system, with an accuracy of up to 3%, making the vehicle safe and reliable when loaded.
The battery management system contains more than 400 battery faulty alarms.
CAN bus management system, real-time monitoring of the status of each circuit, convenient maintenance.
(4) Flexible and multi-functional
Multifunctional accessories
Allows customers to choose different accessories based on their own needs, and also supports customization of accessories.
Quick replacement
Switching between different accessories can be achieved within 3 minutes, greatly improving efficiency.
