Meyer introduces a new concept
- 13 Oct 2005 ( #230 ) - SALZGITTER, Germany
The 180 degree rotating paper roll clamp.
German forklift attachment manufacturer Hans H Meyer GmbH has introduced what it claims to be a new concept, a special 180 degree rotating paper roll clamp.
Manufactured in Hans Meyer's Salzgitter plant, the clamp's 180 degree rotator has a rotating valve that supplies hydraulic oil to its cylinders, eliminating use of a hose. It also has a modular design and all modules are easily accessible and can be changed from the front, Hans Meyer said in a statement.
Cartridge-shaped check valves on the clamp cylinders ensure that, when clamping, hydraulic pressure remains in the cylinder only. Hence the rest of the hydraulic system is without pressure, the statement said.
The cylinders are equipped with test connections that enable simple, exact checks of the clamping pressure.
High tensile bolts inside bushings equipped with grease nipples at the arm or back connection prolong the clamp's working time, Hans Meyer said.
The modular design enables a switch from clamps with fixed short arms to clamps with articulating short arms.
Forklift attachment donated to college vocational program
Forklift attachment donated to college vocational program 25 Sep 2025 - Leicestershire, United Kingdom - 1 min read
Kaup installs record attachments
Kaup installs record attachments 6 May 2021 - Aschaffenburg, Germany - 2 min read
Kaup helps HB handle kegs
Kaup helps HB handle kegs 4 Feb 2021 - Munich, Germany - 1 min read
LogiMAT sees double-digit growth News Story - 6 Mar 2014 - Stuttgart, Germany - 4 min read
Briefs News Story - 23 May 2013 - 1 min read
Bolzoni and Meyer partner in Benelux News Story - 15 Nov 2012 - Helmond, Netherlands - 1 min read
