Lift your game with TVH’s hydraulic parts
- 25 Aug 2022 ( #1091 )
5 min read
Lifting Loads Made Easy
The hydraulic system of warehouse equipment is vital. Loads have to be moved consistently. That is why it is crucial to have the hydraulics in perfect condition. Whether you need hydraulic components for simple or complex hydraulic systems, you will find what you need at TVH. Discover what you can expect from our hydraulic range.
Hydraulic Parts to Raise Your Game
Hydraulic systems consist of many different parts. No matter how big or small, they are crucial for proper functioning. From the smallest seal to the toughest cylinder, everything you need is available in our assortment. Find out more about the parts we deliver below.
Pumps and motors
Hydraulic motors
Easily convert hydraulic energy into mechanical energy with a high-quality hydraulic motor. We offer a variety of hydraulic motors that differ in size, capacity, power, and efficiency. These are the types of motors you can order from our stock:
  • Gear motors
  • Orbit motors
  • Plunger motors (axial and radial)
Hydraulic pumps
  • Gear pumps: commonly used for hydraulic fluid power applications in machines like forklifts. With a simple design, they are a cost-efficient solution that is easy to use and maintain. Our product range includes both internal and external gear pumps.
  • Vane pumps: Vane pumps are distinguished from other pumps by their low noise level, ease of maintenance, and extensive lifespan. Thanks to their high level of quality, they can be used in both low- and high-pressure applications up to 200 bar (2900 PSI).
  • Piston pumps: A piston pump is a highly reliable solution that delivers impressive performance. This type of pump can operate with pressure levels of more than 350 bar (5000 PSI).
Power packs
Power packs are complete units that mainly consist of a motor, a reservoir, and a hydraulic pump. The purpose of this unit is to generate power to drive hydraulic machinery. They can be used in many applications such as electric lift trucks and pallet stackers among many others.
Seal kits
Seals are important and should never be neglected. Whenever repairing or replacing hydraulic parts, it’s a good idea to also replace the seals of the component.
Hydraulic fluid conveyance
Hydraulic systems contain critical components that enable fluids to run from one point to another. At TVH, you will find a comprehensive range of parts that enable hydraulic fluid to flow through any system smoothly and safely.
Hose workshop machines
Cutting machines: after measuring the required length of the hose, you will need a machine to quickly and precisely cut it. These machines are either mechanically or manually driven and equipped with a smooth or toothed steel blade.
Skiving machines: these machines are specialised in removing the external or internal rubber layer until you see the wire braiding. This is necessary in some cases to attach the correct fitting to the hose. If you are looking to avoid this step, use no-skive ferrules.
Crimping machines: these machines are machines either manually or mechanically powered to crimp a fitting onto a flexible hose or tube. These machines range from simple portable models to complex machines for high-volume production.
Hydraulic accumulators
Improve the efficiency, durability, and comfort of your lift truck with a hydraulic accumulator. This part improves all these elements by smoothing the ride for both the driver and the load.  Bumps and potholes are no longer obstacles to safety and comfort.
We have the following types of accumulators, ready to be shipped:
  • Bladder accumulators
  • Diaphragm welded accumulators
  • Diaphragm screwed accumulators
  • Piston accumulators
Fluid conveyance parts
Each application has its own requirements. To make sure your parts fit the desired application, there are endless possibilities when it comes to hose materials, thread types, sealing methods, and much more.
We have a wide range of hydraulic hoses, pipes, adapters, crimp fittings, and accessories for hose mounting. You are guaranteed to find what you need for your application!
Hydraulic valves
Hydraulic valves exist in nearly every industry. They are used in a wide variety of hydraulic systems to control the flow of fluid, usually oil. Simply put, a hydraulic valve opens and closes to allow the flow that will move actuators and loads.
We have everything you need to get your hydraulic system under control:
  • Directional valves (2/2-way, 3/2-way, 4/3-way…)
  • Hydraulic regulators (check valves, flow control valves, pressure relief valves…)
  • Hydraulic valve components (cartridge valves, solenoid coils, base plates…)
  • Seal kits
Hydraulic cylinders
At its root, a hydraulic cylinder is a mechanical actuator that creates linear force through a stroke pushing in a single direction. These hydraulic cylinders can be found in a huge number of applications. At TVH we have a complete range of hydraulic cylinders and parts:
  • Single-acting cylinders
  • Double-acting cylinders
  • Telescopic cylinders
  • Tandem cylinders
You can find more than just plain products, our services extend to testing, repairing, quotations and more. We repair basically every type of hydraulic cylinder. In addition, we have most of the seal kits for these cylinders in stock.
Orbitrol steering valves
Steering units are not usually subjected to much wear and tear, so they usually outlast the machine they are built into. However, some parts of the power-steering system do need to be serviced. Tasks include:
  • Changing shaft seals and O-rings;
  • Disassembling, cleaning and reassembling contaminated parts;
  • Performing hydraulic testing, including valve setting.
At TVH, you will find orbitrol steering valves suitable for all types of material handling machines.
But wait, there is more…
In addition to the products mentioned above, we have a lot more extras for your hydraulic systems.
  • Hydraulic seals: whether you need a kit or a single seal, we have got you covered. You can easily order o-rings, guide rings, piston rings, and much more from our range.
  • Accessories: do you need hydraulic measuring devices, filters, oil, or oil coolers? Rest assured, we can provide everything in no time.
One click away from every hydraulic part
TVH is your reliable partner to deliver the right parts to your doorstep. No matter the make or model, you can rely on us to help you out. Besides our extensive selection of hydraulic parts, we also offer you all the technical support you need.
You are now only one click away from getting the best hydraulic parts at the best prices. Easily shop for hydraulic parts by logging in to MyTotalSource. If you have any questions, don’t hesitate to contact us via e-mail, phone, MyTotalSource, IRMN… Our in-house experts will gladly assist you. Not a customer yet? Create an account and get access to our range in a flash!
TVH Parts Holding NV
www.tvh.com
Global Headquarters (Waregem, Belgium)
Phone: +32 56 43 42 11
Americas Headquarters (Olathe, Kansas)
Phone: +1 913-829-1000
Toll-free: 1-800-255-4109
Muncie, IN, United States
