From production to recycling: Bolzoni Auramo boosts the paper handling cycle Scroll down for video
- 3 Mar 2022 ( #1066 )
4 min read
Heavy-duty Bolzoni Auramo pulp bale clamp, Series BA-100.
Forest products industry is one of the most thriving sectors in the world economy, given that it provides some of the most useful consumer commodities. Printing paper, packaging paperboard, tissue for the household purpose and many more…how could we live without this precious material?
As attention is growing around issues such as sustainability and recycling, the paper industry has always been ahead, playing a pioneer role: paper represents the perfect product to sustain circular economy system and to respond to plastic-free, because of its ability to be recycled again and again.
Recycled paper becomes an essential resource to be managed to protect the environment. Producing paper in a sustainable way today, means respecting forests rhythms and balances, safeguarding biodiversity and productivity.
Paper: a precious commodity to be produced and recycled
Since paper can be classified as a renewable resource, recovery is crucial within the paper industry.
The recycling rate of paper and cellulose packaging is increasing and so it is the number of specialized small and medium-sized paper recovery companies.
Forest products, such as pulp bales and waste paper, are some of the most demanding cargo commodities, requiring specialized lift truck attachments, because of their weight, large dimensions and need of dedicated handling procedures.
Thanks to its expertise, Bolzoni Auramo is well known as an excellence in paper handling solutions. Over the years, working closely with the main paper companies, Bolzoni Auramo has improved and consequently expanded its range of dedicated paper handling products, specializing on all paper requirements from paper mills, to port terminals and recycling centers.
Among implemented paper handling solutions, we present a selection of highly dedicated forklift truck attachments, designed and implemented together with the paper handling experts on the field. Let’s focus on main technical features, which need to be taken into consideration when choosing a new specific-for-paper attachment.
BC-BA: a dedicated clamp Series for pulp and waste paper bales handling
The thin profile of the arms facilitates close storage and penetration between loads.
Bolzoni Auramo BC-BA series clamps are designed for heavy-duty handling of pulp and waste paper bales, and for use on both forklifts and wheel loaders.
The extremely slim and lightweight design offers a high residual capacity. Furthermore, the wide selection of arm openings and lengths allow efficient handling of 1-3 units of cellulose bales.
The oscillating left arm offers safe grip on the bales. The frame of the clamp is made of special welded steel "T" profiles. Therefore, the clamp is extremely rigid and robust. Bearings in the frame are easily replaceable and require minimal maintenance. A wide range of arms with different friction surfaces and hydraulic options are available on request. For this model we can offer special design arms: in order to have safer grip on top of the bale and reduce the risk of loose grip when handling multiple bales. For dedicated handling of waste paper bales, we recommend our BA-W clamp model.
Full grip on pulp paper handling with the BA-100P clamp Model
With capacities up to 10.000 kg @ 800 mm load center (22,000 Lbs @ 31.5''), it is possible to handle from 1 to 4 pulp bale units of all sizes.
Modern pulp handling requires equipment capable of lifting varying load sizes and bale unit combinations.
Pulp bales are sensitive to mechanical damage, moisture and contamination, causing problems in further handling and processing. Effective wood pulp handling requires specialized equipments.
The Bolzoni Auramo clamp BA-100 model is designed for effective and safe heavy-duty pulp bale handling. Typical applications are in pulp mills, but it is employed also in warehouses, terminals, stevedoring docks and other loading and unloading operations in the logistic chain.
The main features are:
  • Steel profile frame with strong “T” profile arm carrier.
  • Welded profile frame with heavy-duty bearings offering performance advantages and longer lifetime.
  • Arms welded to the arm carriers. Colorless arm finish.
  • Slim and strong-arm design ensures easy knifing and tight stacking.
  • Left-side arm pivots to compensate differences in bale unit sizes. Compact and strong pivot design offers exceptional strength and service life. Fixed left arm is available on request.
  • Side shift valve with built-in pressure relief valve for both clamping and opening.
  • Clamping cylinders with flexible mountings for heavy duty handling.
BA-W Series: for the tough waste paper bale handling
BA-W heavy-duty clamp with wear and shock protections on the frame. Perfect fit on wheel loaders too.
Collecting and transporting recycled waste paper is one of the toughest applications in the forest products handling chain. Waste paper bale handling is generally harsher than any other bale handling operation, and attachments often need increased protection against wear and tear. This clamp has all moving and hydraulic components well protected.
The Bolzoni Auramo model BA-W clamp is specifically designed for heavy-duty handling of waste paper bales in the paper industry, and it is widely employed in the plastic and recycling materials handling as well.
With capacities ranging from 1.600 kg @ 600 mm to 7.000 kg @ 900 mm load center (3,500 Lbs @ 23.6’’ to 15,400 Lbs @ 35.4’’) and with a wide choice of opening ranges, arm lengths and options, this clamp is the best solution to the widest variety of handling needs.
BA-100
For more information on PULP AND WASTE BALE handling solutions, get in touch with the Bolzoni Group Paper Logistics Specialist, send an email and ask for our references on Paper Handling Solutions, or to organize a demo unit at your facilities.
Visit the dedicated Paper Products section on our web site and contact us by email, or contact the nearest BOLZONI AURAMO and MEYER representative.
Bolzoni Auramo and Meyer are Bolzoni Group brands.
Bolzoni is a market leader in the production of forklift truck attachments, forks and lift tables. The company has manufacturing plants in Italy, Germany, Finland, America and China and through its network of direct branches and independent dealers, covering all continents it is able to satisfy all market requirements.
Bolzoni SpA (Group HQ)
+39 052... Show
Via I Maggio, 103
I-29027 Casoni di Podenzano,
PC, Italy
