Ningbo Ruyi Joint Stock Co., Ltd. is proud to present their family of ORDER PICKERS - to meet all your needs in different height rack warehouses.
1. Mini Order Picker - OPSMYour best choice to reduce labour costs, increase efficiency, and reduce product damage cost during handling.
The
OPSM Mini Order Picker boasts the following characteristics:
- Safety Guard - active sensor automatically cuts the power cycle if the platform is above 500mm and the gate is left open. Meanwhile, the lifiting speed will decelerate for safety concerns.
- Dual Foot Pedals - will detect if the operator has both feet properly positioned on the platform.
- Hand Sensor - on the control handle to start travel, lift and lower.
- Adjustable Loading Tray - 260mm adjustable height of loading tray, offers desired position at work.
- On-Board Charger - makes it possible to charge battery whenever it is needed.
Model Name |
OPSM |
Load Tray Capacity |
90 kg |
Load Dock Capacity |
150 kg |
Platform Lift Height |
3000 mm |
Rated Voltage |
24 V / 200 Ah |
Traveling Speed |
4.5 km/h |
Turning Radius |
1300 mm |
Overall Length |
1500 mm |
Service Weight |
750 kg |
2. Low level Order Picker - OPL10SThe low level order picker OPL10S with lifting forks elevates pallet loads weighing as much as 1000kg and up to 1200mm high, providing ergonomic and productivity advantages.
The
OPL10S Low level Order Picker provides the following:
- Loading Tray - large sized tray with loading capacity of 60kg.
- USB Charge Device - located on the control panel, use to charge phone, pad, etc.
- Foot Switch - to ensure safety.
- straight Driving Control - located on the backrest, enables operator to pickorders while off the truck.
- Extra Control Button - extra fork lifting and lowering control button located at the backrest of platform.
Model Name |
OPL10S |
Load Capacity |
1000 kg |
Platform Height |
1200 mm |
Max Lifting Height (fork) |
800 mm |
Rated Voltage |
24 V / 450 Ah |
Traveling Speed (laden/unladen) |
7.7 / 7.8 km/h |
Lift Speed (laden/unladen) |
0.1 / 1.15 m/s |
Lowering Speed (laden/unladen) |
0.07 / 0.08 m/s |
Turning Radius |
1535 mm |
Service Weight |
1535 kg |
OPL10S Standard Configuration:
| AC System | EPS System | Side-way Battery |
| Advanced AC system control with reliable performance is easy to maintain. | Advanced electric power steering (EPS) handle ensures effortless and highly efficient maneuverability. | Side-way battery design is very convenient for maintenance and replacement. |
3. High Level Order Picker - OPS15The high level order picker OPS15 provides safety and high efficiency order packing for high racked warehouses.
The
OPS15 High Level Order Picker has the following great characteristics:
- Pallet Lock Device - locks the pallet to ensure safety.
- Protective Guardrail - equipped with a safety switch design to ensure that the truck can start when completely closed.
- Light and Fan - to provide the operator with a better driving and operating experience.
- CURTIS Multi-function Display - shows battery status, performance, working hours, accelerator, speed, the wheel position, and traveling direction.
- High Quality Mast - special mast material imported from Germany
Model Name |
OPS15 |
Load Capacity |
1500 kg |
Max Lifting Height |
5000 / 7000 / 9000 mm |
Rated Voltage |
24 V / 700(1100) Ah |
7.7 / 8 km/h |
0-0.15 / 0-0.28 m/s |
0-0.28 / 0-0.3 m/s |
Turning Radius |
1800 mm |
Service Weight |
3870 kg |
OPS15 Standard Configuration:
| EPS | AC System |
| Advanced electric power steering (EPS) is humanized design with automatic reset, height display, and automatic deceleration at high lifting levels. | AC motor eliminates replacement of the carbon brush, provides good ramp starting performance and regenerative breaking functions. |
| Side-way Battery | Low-Battery Protection |
Side-way battery design is convenient for exchanging and maintenance. | Low battery protection setting prolongs the battery use time. |
All order pickers can optionally be fitted with a Lithium battery.For more information about this family of order pickers, please contact:
Tel: 0086-574-65552006
Web: www.xilin.com
Email: send an email
Visit our ShopFrontAbout Ningbo Ruyi Joint Stock Co., Ltd.
Ningbo Ruyi is a market leader in the production of hand/electric pallet trucks, manual/electric stackers, forklift trucks and others with over 33 years history. The company has a strong R&D team made up of 188 professional technicians, 77 senior engineers, withholding 145 national patents. The market covers 157 countries and regions throughout the world and it is able to meet all market requirements.
