Safety, collision prevention and load handling
- 31 May 2018 ( #874 )
Sensors, switches, control systems, software and services - SICK offers the world's largest product portfolio for driverless transport systems, semi-automated industrial trucks and mobile platforms. The company supplies alternative sensor technologies for many tasks, whereby the individual complete vehicle solutions ensure maximum economic efficiency, as well as functional reliability and future security.
Personal safety for mobile applications
Mobile intralogistics machines, such as driverless transport systems and mobile platforms, increasingly work at the same time and in the same environment as persons. This requires the use of safety-certified sensor and control components based on individual risk analyses and the applicable Type C standards. Safe encoders and safe, non-contact limit switches monitor the speed as well as the current and maximum permissible steering angle of vehicles. Safety laser scanners with individually programmable protective fields detect persons and obstacles on the drive path and decelerate the vehicle down to a safe stop. 360° all-around protection can be set up with just two safety laser scanners. They are coordinated by a modular safety controller that combines the signals from the safe encoder, 2D LiDAR sensors, limit switches and emergency stop buttons - enabling smart situation-dependent detection of persons. The configuration of the safety technology can be carried out individually for every vehicle type and every application. The solution is characterised by economic efficiency, safety and high availability.
Localisation and collision prevention - for trouble-free navigation to the destination
Many roads lead to Rome - many sensor solutions lead to the destination. Thus SICK offers both optical and magnetic track guidance systems from a single source for driverless vehicles and platforms. Each of these two technologies offers particular application-specific advantages. As an alternative, a solution for automatic correction of vehicle position can be used with a system for grid localisation via data matrix codes. Laser positioning sensors mounted high on vehicles detect spatial marks and localise reflectors very rapidly and precisely. Their 360° spatial contour data are transmitted to the vehicle computer for localisation and navigation purposes. Innovative 3D LiDAR sensors that offer active measuring on four scanning planes not only enable navigation (also outdoors) but simultaneously provide efficient collision prevention if, for example, objects are lying on the ground or jutting into the drive path from the side. Effective collision prevention and a solution for detecting and measuring loads can be achieved on driverless transport vehicles with the help of configurable 3D snapshot detection sensors that can capture up to 30 images per second.
Sensor solutions for the automatic handling and identification of transport packages
SICK's sensor portfolio offers one or more suitable solutions for almost every functional task on driverless transport systems and mobile platforms. On forklift trucks, for example, distance sensors monitor the lifting fork's approach to a pallet. After uptake of the load, a wire draw encoder measures the lifting path of the fork while inclination sensors measure the current angle. At the same time, the pallet can be automatically identified with a barcode scanner, a camera-based code reader, or an RFID interrogator. While measuring the path in the hydraulic cylinder of the lifting fork, innovative linear encoders provide not only precise position information but also comprehensive diagnostic functions that can be used to prevent machine failures, optimise maintenance routines, and increase vehicle availability. Mobile automation in the intralogistics also offers a wide field of activity for ultrasonic sensors, photoelectric switches and proximity sensors.
Given the extent to which mobile intralogistics, as well as mobile assistance and service robots, are penetrating new applications, complete sensor solutions from SICK will continue to grow with the new challenges.
SICK Pty Ltd
1800 334 802
Send an email
www.sick.com.au
ShopFront
September 23-25, 2025 - SÃO PAULO, Brazil
October 15-16, 2025 - Las Vegas, United States
November 25-26, 2025 - Singapore, Singapore
