FOREWARNER-LED warning lights improve awareness of pedestrians
- 19 Oct 2017 ( #843 )
5 min read
FOREWARNER-MAXI
FOREWARNER-MAXI
Industrial plants have forklifts, heavy equipment, personal carriers and overhead cranes busily working with operators of these machines, concentrating mainly on the load being handled and their job at hand. Operators are frequently multitasking and in a hurry to complete their material handling task. Pedestrian workers are also busy doing their job in the same proximity as these material handling machines - major safety hazards in play.
AUDIBLE ALARMS ARE LIMITED
Audible beeping alarms are fine and have been used successfully for many decades. However audible alarms are frequently "drowned out" and ignored as workers get used to the sound especially in loud industrial settings. Today there is also more widespread use of worker ear plugs mandated by corporate safety to protect the worker. This problem with audible alarms is exacerbated when there are multiple lifts and cranes working simultaneously in the same area.
FOREWARNER lights do not take the place of audible alarms, but do provide additional visual warning that is proportional to the proximity of the moving equipment hazard.
An audible beeping reverse alarm serves more as a general caution to employees working in the area, however this still requires workers to identify the hazard and assess whether its proximity is dangerous. Unlike an audible "beep"- the actual movement of a light on the floor from a forklift or overhead crane provides a definitive warning to affected pedestrian employees - those in the immediate danger area.
FOREWARNER LED lights are specifically designed for both forklifts and overhead cranes and are available in spot, line, laser and arrow designs projected on the floor below.
FOREWARNER-MAXI
FOREWARNER-MAXI
FOREWARNER MAXI lights improve safety on overhead cranes:
  • Reduce accidents!! 80 lift and material handling equipment workers are killed each year, on average
  • Reduce incidences of human error - pedestrians are more aware of moving load
  • Pedestrian workers are frequently working in close proximity to crane handling operations
  • Pedestrian sees projected line or spot on floor - knows his proximity to the moving load
  • Very effective for overhead cranes working in areas with many pedestrians
  • Pedestrian workers can get "immune" to the beeping sound of overhead cranes in use
  • Beeping audible alarms do NOT provide a pedestrian with a sense of proximity to the load on the crane
  • Crane operators have a new "frame of reference" as to the exact position of load/hook above the floor
  • Significantly improves operator control of the load, especially when exact positioning is required
  • Operators do not have to take their eyes off the crane block or load to know trolley is centered over the load
  • LED lines can create a square "box" around the load/hook on floor below - obvious "danger area"
  • Pedestrian worker sees colored line or spot on the floor - knows load is moving and his proximity to it
  • Snap on lens cover turns spot on the floor into line on the floor - allows user to "box" in the hook
  • Moving lines/spot on the floor prevents pedestrians from walking under suspended load
  • Operators control overhead cranes from a cab far above the floor or a pendant from operator on the floor
  • When a load on a crane is stopped suddenly, there is significant hook/load sway
  • Workers are concentrating on their job at hand and may NOT see the moving load in their area
  • Crane operators concentrate on the load they are handling and may NOT see workers
  • Powerful 24 MAXI LED 120 watt light projects RED - BLUE or WHITE spot or line (with lens cover)
FOREWARNER LED lights improve safety on forklifts:
  • Reduce accidents!! 40+% of all fatal forklift accidents involve pedestrians
  • Pedestrian sees projected line or spot on floor - knows to stay outside of that perimeter
  • Very effective for forklifts working in areas with many pedestrians
  • Pedestrian workers can get "immune" to the beeping sound of reversing forklifts
  • Beeping audible alarms do NOT provide a pedestrian with a sense of proximity to the forklift
  • Many pedestrians don't understand the crushing force of a forklift tire or rear end swing
  • Conventional loaded warehouse forklift weighs over 10,000# high mass and poor stopping distance
SIDELINERS improve safety on forklifts:
  • Pedestrians sometimes get too close to working forklifts - very dangerous!
  • Solid tire cushion forklift tire will easily crush a foot - leading to a permanent disability
  • Workers can try to "squeeze by" forklifts and can get seriously hurt
  • Creates a visible "SAFE ZONE" border - obvious to pedestrians to stand and walk clear.
  • Many times pedestrian workers are to the side of the forklift - and do not see LED light in front or back
  • FOREWARNER SIDELINERS are available in both 6 LED and laser versions
  • SIDELINER GREEN or RED line on floor determines distance from forklift
CONCLUSION:
FOREWARNER equipment safety LED spot and line lights create significantly more pedestrian awareness of both forklift and overhead crane movement. Lights create a culture of safety awareness by preventing both operators and walking employees from being in the wrong place at the wrong time thus minimizing the potential of a preventable accident. FOREWARNER demo units are available call 813-877-4500 or send a message to the Sales Team.
For more information view website: www.keytroller.com or contact KEYTROLLER, LLC. 813-877-4500 or email: send a message or visit the KEYTROLLER ShopFront.
About Keytroller, LLC
Keytroller is committed to the design, manufacture and supply of proprietary safety devices designed for forklifts, construction equipment, aerial lifts, personal carriers and transport trucks. Originally established in 1988, Keytroller is headquartered in Tampa, FL and enjoys relationships with over 500 North American equipment dealers (aftermarket) many OEM vehicle manufacturers (installed as original equipment). Importers of our products are in England, Japan, Australia, Singapore, Middle East, Brazil, Mexico, Canada, Chile and Columbia. Keytroller also has manufacturing/distribution agreements with partners in England, Chile, Singapore, Malaysia, Columbia, Middle East, Caribbean, Australia and Taiwan. Visit www.keytroller.com for more information.
Muncie, IN, United States
