Keytroller’s COOLTROLLER Products Keep Forklift Operators Cool and Productive All Summer Long
- 24 Aug 2017 ( #835 )
4 min read
With yet another scorching summer upon us, it's imperative that both employers and employees are aware and prepared for the dangers of heat stress. Workers exposed to extreme heat (both indoor and outdoor) may be at risk for heat stroke, which can lead to serious illness and even death. Forklift operators are especially at risk, since they often perform long shifts in these conditions. Fortunately, Keytroller has the perfect solutions!
COOLTROLLER - SEAT
Purchase online HERE
This 16" x 16" (41cm X 41cm) cushion has 2 fan air intakes. These fans push a cooling breeze through the cushion and up between the bamboo platelets and up to the operator's bottom or back.
INSTALLATION:
Not much to it - just connect to 12-48VDC input power and set the cushion on the seat for the operator to sit on or lean it on the seat back for the operators back to lean against. Either way, the moving air will be a welcome relief to a forklift operator who often is sitting over top of a hot engine compartment.
Each COOLTROLLER-SEAT includes:
  1. 16" x 16" seat with 2 input fans and bamboo platelets for dispersing air out
  2. 5' cable
  3. On/off switch in line in cable-should be connected to switched power.
  4. Be sure to order proper model for 12VDC or 24-48VDC input power!
Features:
  • EASY TO INSTALL - Just place on seat and sit on it or place on back of seat and lean on it
  • 2 wires to power (12 VDC), Voltage converter included in 24-36-48 VDC model
  • Sized to fit to any seat
  • Moving air continuously cools drivers bottom or back - operators love it!
  • Heavy duty bamboo platelets insure long life and cool air outlets to sit on
  • Low current draw of 3W - minimum load on vehicle electrical system
Purchase Price: $70 (12V model) / $80 (24-48V model). Dealer discounts available. Purchase online HERE
COOLTROLLER-DUAL FANS
COOLTROLLER Dual Fans by Keytroller
A cool operator is a productive operator! Economical and easy way to cool down your drivers!!
Dual fans generate cooling breeze pointing down at your equipment operator. Motors are 100% copper wound for longevity.
Powered by 12VDC or 24-48VDC input power typically connected to vehicle switched ignition power. There also an on/off Hi/Lo switch on the fan module.
Full 360 degree all around adjustment of both motors on the module - Up/Down and Right/Left allows operator to easily direct cooling breeze where he wants it!
INSTALLATION:
Not much too it just connect to 12-48VDC input power. Double sided tape makes it easy to mount the dual fan module on the overhead guard or rack of most vehicles. Many clients further secure the assembly with plastic cable ties.
Each COOLTROLLER-DUAL FANS Kit includes:
  1. Dual adjustable position fans
  2. 5' cable (12VDC input only) Voltage converter required for 24-48VDC vehicles
  3. On/off switch on device with Hi/Lo settings - should be connected to switched power
Features:
  • EASY TO INSTALL - mounts to overhead guard, in front, behind or beside the operator
  • 12 VDC Model and 24-48 VDC model Be sure to order by input voltage!
  • Each fan head is independently adjustable
  • 360 degree both horizontal and vertical
  • 100% pure copper motors
  • Ultra quiet - low noise design <45dB
  • On/Off - Two speed switch on device
  • 8"H X 3.5" D X 5.5" H small enough to fit to most any vehicle
Keytroller hopes you'll make your forklift operators a little "cooler" this Summer!
For more information visit www.keytroller.com or contact KEYTROLLER, LLC.
Ph: 813-877-4500, send an email or visit the KEYTROLLER ShopFront
About Keytroller, LLC
Keytroller is committed to the design, manufacture and supply of proprietary safety devices designed for forklifts, construction equipment, aerial lifts, personal carriers and transport trucks. Originally established in 1988, Keytroller is headquartered in Tampa, FL and enjoys relationships with over 500 North American equipment dealers (aftermarket) many OEM vehicle manufacturers (installed as original equipment). Importers of our products are in England, Japan, Australia, Singapore, Middle East, Brazil, Mexico, Canada, Chile and Columbia. Keytroller also has manufacturing/distribution agreements with partners in England, Chile, Singapore, Malaysia, Columbia, Middle East, Caribbean, Australia and Taiwan. Visit www.keytroller.com for more information.
