High Capacity Material Handling: Can Your Fleet Handle It?
- 28 Apr 2016 ( #767 )
4 min read
A Taylor Machine Works reach stacker performing cold weather duty.
Markets change, trends come and go, but as long as there is industry, there will be a need for high capacity material handling equipment. And when it comes to moving big loads, cutting corners can cost you. That's why it's time to take a long, hard look at your fleet of equipment and ask yourself if your machines are really up to the challenges of your duty cycles.
Since its founding in 1983, H&K Equipment has specialized in the lift trucks that can do the jobs that other machines can't. We provide complete lines of heavy duty lift trucks in all capacities up to 120,000 pounds for any industry where loads have to be transported safely, quickly, and without a lot room for error.
We also provide best-in-class parts and service support for any make or model of material handling equipment. If you need to fix a machine or make a machine run better, there's no one better to call.
Don't put it off, call 1-800-272-9953 for material handling solutions that work for you.
A new Elwell-Parker L15 platform truck engineered by H&K Equipment.
Specialized Equipment for the Auto and Steel Industries
H&K Equipment's corporate legacy dates all the way back to 1935 when we were first founded as a dealer of Elwell-Parker material handling equipment in western Pennsylvania. That gives us nearly 80 years of experience in working with some of the biggest businesses in the steel and auto industries, many of which continue to use Elwell-Parker lift trucks for die and coil handling operations. This includes the L15 platform truck, which is now available newly engineered in a 25,000-pound capacity model. As the OEM of Elwell-Parker since 2010, H&K Equipment can service, engineer, and build new or existing Elwell-Parker lift trucks in any capacity.
H&K Equipment is the OEM for all Elwell-Parker products. For parts, service, upgrades, or to invest in a new Elwell-Parker lift truck, call 1-800-272-9953.
GOING TO AISTECH 2016? VISIT H&K EQUIPMENT AT BOOTH #1529
The Complete Line of Taylor Forklifts
H&K Equipment is proud to represent the complete Taylor Machine Works product line for sales, rentals, and service. This includes the X Series of forklifts and the XRS-9972 container handler, both from Taylor Machine Works. With capacities ranging up to 70,000 pounds, the X Series line features the ultimate forklifts for handling mid-to-high range loads in grueling day-to-day duty cycles. The XRS-9972, meanwhile, is engineered specifically for ports and can stack 41 ton containers five rows high without a drop in speed or handling performance.
A Taylor
A Taylor "Big Red" forklift, part of the core lineup of H&K Equipment's high capacity fleet.
H&K Equipment is proud to represent the Taylor Machine Works product line for sales, rentals, and service. Call 1-800-272-9953.
The Pettibone Cary-Lift rental fleet on standby at H&K Equipment.
Pipe Handling for Mining, Construction, and Oil and Gas Industries
The recently redesigned Cary-Lift 154 pipe handling truck adds even more versatility to Pettibone's Cary-Lift Series, with standard-setting features that reflect how material handling, and pipe handling in particular, has evolved in recent years. Coming in at the low end of the heavy-duty spectrum with a maximum capacity of 15,000 pounds, the Cary-Lift 154 meets an important but underserved need for rough terrain lift trucks that are more powerful and rugged than smaller equipment, but are also more cost-effective than their higher capacity cousins.
All models from the Cary-Lift Series are available for sale or rent from H&K Equipment, including options with up to 30,000-pound capacities. Call 1-800-272-9953.
A JLG G12-55A telehandler at one of H&K Equipment's sister companies in Baltimore.
Rough Terrain Telehandlers for Construction and the Oil and Gas Industry
The G12-55A telehandler from JLG brings the maneuverability of a forklift and the reach of a crane to your jobsite. Designed to transport loads off-road and over uneven terrain, the G12-55A has the power to travel to areas other material handling equipment can't, and it can do it with better cost-efficiency than other telehandler models. The Tier 4i compliant 4.5 liter Cummins diesel engine gives the G12-55A 12,000 pounds of capacity, while the sturdy boom can extend a full 55 feet. Large pneumatic tires, enhanced steering, simplified controls, and improved sightlines make this model a must-have for oil and gas development, construction, and other outdoor applications.
The complete line of material handling equipment from JLG is available for sale or rent. Call 1-800-272-9953.
A Stewart & Stevenson Rail King RK 330 G5 railcar mover at work.
Mobile Railcar Movers for Railcar Switching, Loading, and Unloading
For nearly 25 years the Rail King railcar mover from Stewart & Stevenson has redefined railcar switching. Now in their fifth generation, Rail King models are designed to support rail-heavy facilities in warehousing, chemical, bulk commodity, and agricultural industries. Entries in the new G5 series are available with nearly 50,000 pounds of tractive effort. To further improve productivity for railcar operations, especially in wild or unimproved environments, H&K Equipment also supports the Speed Swing Loader Series from Pettibone. These incredibly versatile machines can do everything from laying rails and clearing track paths to loading rail cars and ferrying equipment. Available in capacities up to 15,000 pounds.
H&K Equipment is a leading representative of both Pettibone and Stewart & Stevenson products. To discuss these machines, please call 1-800-272-9953.
A new Pettibone Speed Swing at H&K Equipment, featuring one of many available attachments.
H&K Equipment is proud to be the founding member of the H&K Equipment Family of Companies, a vibrant interconnected material handling network with multiple locations in Pittsburgh, Philadelphia, Baltimore, and New Castle, Pennsylvania and Syracuse, New York.
Contact Information:
H&K Equipment
Richard Rich,
Wholesale Distribution Manager
Phone: (412) 490-5300
Mobile: (412) 779-3056
send an email
www.hkequipment.com
For more company and product information, Click to view the H&K Equipment ShopFront
Get in touch with H&K Equipment Company
+1 (0)4... Show
4200 Casteel Drive,
Coraopolis, PA 15108,
United States
ASSET FINANCE
Nov 2025
ASSET FINANCE
Nov 2025
ASSET FINANCE
Nov 2025
