Presenting the Latest in Material Handling Solutions at LogiMAT
- 25 Feb 2016 ( #758 )
Cascade, the global leader in
lift truck attachments, forks, accessories and material handling solutions, will exhibit at LogiMAT 2016 in Stuttgart, March 8-10, 2016 - Stand 8C01, Hall 8.
Cascade will be debuting their new J-Series White Goods Clamp, ideal for the white goods and appliance industries. Some features of the new J-Series Clamps include full length, lube-free bearings, a thin arm profile with tapered leading edge, and high-strength steel corner castings that eliminate corner pinching damage. Force distribution is also ensured by the patented three-finger arm design that allows six adjustment points on each arm.
The new J-Series White Goods Clamp on display will be shown with optional VFC (Volumetric Force Control). VFC automatically adjusts clamping pressure based on the volume of the load. This option is designed to reduce damage caused by excessive force applied to the load when manually controlling the pressure. The VFC calculates the size of load and will clamp with the right amount of force.
Cascade will also exhibit the Stationary Fork-Mounted Layer Picker, ideal in beverage, warehouse and distribution facilities. The Fork-Mounted Layer Picker conveniently slips onto a lift truck's existing forks for quick installation and removal, perfect for applications that only have occasional need for layer picking. The fork-mounted Layer Picker can be mounted on a Sideshifter for added versatility.
Cascade's product line includes a wide range of Push/Pulls, Multiple Load Handlers, Fork Positioners and Rotators. Ask about the innovative Fork Positioner Conversion Kit that transforms F-Series Sideshifters into K-Series Fork Positioners with just nine bolts.
Cascade also manufactures standard and custom forks as well as DAGS Magnetic Fork Covers. These fork covers can be installed and removed in seconds, making them the ideal option to protect and help stabilize slippery or awkward loads.
Cascade's highly skilled sales people can recommend a customizable material handling solution based on your needs, including rental and remanufactured alternatives.
Click here for tickets or to make an appointment to speak with someone at the show. You may also email them directly or call +49 211 59 89 55 0.
If you cannot attend the show, visit www.cascorp.com for more information about Cascade, the new PERFORMANCE two-year warranty, or for information about Cascade products and services.
Cascade Corporation
Portland, Oregon
1-800-CASCADE (227-2233)
www.cascorp.com
For more company and product information visit the Cascade ShopFront
1 800-... Show
Corporate Office
2201 NE 201st Ave,
Fairview, OR 97024
U.S.A
Briefs United States
