Cascade to Exhibit at Logistica 2015 in November
- 22 Oct 2015 ( #741 )
Cascade, the global leader in providing material handling solutions, including sophisticated forklift attachments and custom forks, will exhibit at Logistica 2015 in Utrecht The Netherlands from the 10th till the 13th of November. (Stand 11D034)
Cascade will be showcasing products for the paper, beverage, food, recycling, forging, warehousing, white goods, port and harbours industries and many more, featuring a variety of products including their intelligent White Goods Clamp.
The WG series with VFC (Volumetric Force Control) is an innovative combination of electronic systems and hydraulic mechanisms paired with unrivaled Cascade design and structure. The Volumetric Force Control (VFC) automatically adjusts clamping pressure based on the volume of the load. This product is designed to reduce damage caused by excessive force applied to the load when manually controlling the pressure. The VFC calculates the size of load and will clamp with the right amount of force. Force distribution is also ensured by the patented three-finger arm design, the six adjustment points on each arm, the Cascade proprietary Adjusta-Block system and the extended height arm. The White Goods Clamp with VFC is designed to maximize efficiency and speed as well as to protect the load of packed products (including the profiled arm corner casting to eliminate corner pinching damage).
Cascade will also exhibit the G-Series Sliding Arms Clamp for Recycling. This product model can be equipped with arms for bales or forks. The model with arms features arm corner casting to provide superior strength over the life of the clamp, hardened full width wear strip to protect the frame from damage when scraping on the ground, full width lip over UHMW bearings to provide maximum resistance and bearing support and the hydraulic circuit is protected but easily accessible for servicing.
Stop by our booth to learn more about Multiple Load Handlers. Cascade Single Doubles allow drivers to use the same lift truck to handle either single or double pallet loads. Spread the four forks to handle two pallets side-by-side. Forks are hydraulically positioned for fast and efficient handling.
Cascade sideshifting and non-sideshifting Fork Positioners save time and avoid product damage by allowing drivers to position the forks directly from the truck cab. Ask about the innovative Fork Positioner Conversion Kit that transforms Sideshifters into Fork Positioners with just nine bolts.
Paper Roll Clamps can be equipped with different types of pads for damage-free handling of any type of paper. Cascade manufactures both large and small capacity Paper Roll Clamps specially designed for use in ports, mills, warehouses, publishers and anywhere you need to deliver a perfect roll every time.
Visit Stand n. 11D034 to discuss products for your specific application. Cascade's highly skilled sales people can recommend a customizable material handling solution based on your individual needs, including rental and remanufactured alternatives.
For complimentary tickets, to schedule your appointment, or for more information about our products and services, visit: http://connect.cascorp.com/Logistica2015NL_EN.
About Cascade Corporation:
Cascade Corporation was established in Portland, Ore. in 1943 and is the global leader in the design, manufacture and marketing of material handling and construction equipment and related technologies. Cascade's unmatched service, support and expertise, combined with their advanced damage reduction technologies, flexible manufacturing, short lead times and quality products, strengthen the company's position as the premier supplier to the material handling industry. For more information visit www.cascorp.com.
Cascade Corporation
Portland, Oregon
1-800-CASCADE (227-2233)
Send Cascade an email
www.cascorp.com
For more company and product information visit the Cascade ShopFront
1 800-... Show
Corporate Office
2201 NE 201st Ave,
Fairview, OR 97024
U.S.A
