No WiFi wireless? No problem with KEY-MESH wireless WiFi “hot spot” system
- 13 Mar 2014 ( #658 )
Click for larger image
No WiFi wireless in your plant? Want to download and program monitoring systems wirelessly without large expense?
Want to create a wireless hot spot zone in minutes---with no wiring?
Set KEY-MESH hot spot zones around loading dock, fueling area or battery charging area.
KEYTROLLER's new generation color LCD601 wireless access monitoring system features a built in WiFi radio. The Keytroller device is given it's own unique IP (internet protocol) address and configured to utilize the same encryption (security) scheme as the APs are using. When the vehicle comes into wireless range, KEYPATROLLER software automatically makes connection and downloads event log data. Unlike cellular communication systems, KEYTROLLER'S WiFi has NO monthly subscription costs since all data is transmitted through the user's LAN (Local Area Network) directly into software residing on their own server.
Keytroller's KeyMesh
Many large users already utilize WiFi APs (access points) positioned throughout the warehouse. If the company does not have an existing wireless infrastructure KEYTROLLER now offers the KEY-MESH system. It is a LAN (Local Area Network) that can quickly and inexpensively be set up and offers plug in "repeaters" to further expand range. Since there are no cables from the router to the repeaters, the system is exceedingly easy to install and set up.
The expense and inconvenience of retrofitting buildings, offices, warehouses, etc with conventional cabling can be expensive and time consuming in smaller operations. The KEY-MESH system solves this problem by spreading wireless connectivity across the warehouse or many rooms -far beyond the range of a single wireless router that you might find at a computer store.
Check out KEYTROLLER'S new KEY-MESH wireless WiFi "hot spot" zone system.
Used in conjunction with Keytroller's LCD 601 access monitoring system
  • Standard KEY-MESH kit includes router and 2 "repeaters"
  • Router plugs into 110VAC power
  • Each router plugs into 100VAC power about 105' away on each side of the router
  • Host PC with Keytroller software installed within confines of the zone
  • Standard kit creates "hot spot zone" of about 400'-500'
EASY TO INSTALL
  • NO WIRES OR CABLES ---JUST PLUG COMPONENTS INTO POWER. INSTALLS IN MINUTES
  • Configure host PC to the WiFi KEYMESH network
EASY TO OPERATE
  • Have system working within minutes of installation
  • When Keytroller equipped forklifts enter the "hot spot zone"---they automatically connect to the network
  • If the Keytroller devices have event log data---they immediately push the data into the wireless network
  • Data is stored on SQL database in the client's server
ADDITIONAL REPEATERS INCREASE ZONE SIZE
  • Add up to 3 additional repeaters in a "star" around the router to increase the size of the wireless "hot spot zone"
AUTOMATIC REPORT AND EMAIL GENERATION
  • KEYPATROLLER FMS software automatically creates reports, emails and text messages
INEXPENSIVE
  • Installation of KEY-MESH done at a fraction of the cost of a complete wireless network.
Come see KEYTROLLER at MODEX 2014, booth #4105,
Keytroller will exhibit their wide range of forklift safety products for all makes and model forklifts.
For more information view website: www.keytroller.com or contact KEYTROLLER, LLC. 813-877-4500 or email: send a message
Click here to visit the KEYTROLLER ShopFront
