Problems seeing loads at high levels? Blind when handling long awkward loads or boats? Blind corners a problem? Want a "look down view" from the top of a crane boom? Want a removable "back up camera"Check out KEYTROLLER'S new SEETROLLER wireless digital video camera for forklifts and equipment.- Install SEETROLLER onto forklift with 1-2-3 or 4 cameras simultaneously recording video from different camera angles and directions.
 Click for larger image |
- Choice of standard (with automatic infrared night vision) and waterproof outdoor cameras
- Color 7" LCD display mounts for operator's view
- Color 7" LCD display has hand held FOB for turning each remote camera on/off
- Color 7" LCD display has split screen for 1-2-3 or -4 camera inputs
- Each camera is powered by rechargeable battery
- Each camera has RF switch with adjustable time off timer
- Device records continuous overwritten video to removable SD card
EASY TO INSTALL- NO WIRES OR CABLES TO RUN, BREAK OR WEAR OUT. INSTALLS IN MINUTES
- 7" Display: 2 wires to power (12 VDC), Voltage converter for 24--36--48 VDC
- if no signal from camera, display turns off immediately
- Includes flat surface / in-dash and adjustable universal mounts
- Cameras: Mount where you choose along with rechargeable battery pack
EASY TO OPERATE- Have system working within minutes of installation
- Turn camera on/off with remote control wireless RF FOB
- Image automatically appears when remote camera is triggered on by FOB
- Camera is turned off by FOB or will turn off immediately after reaching end of adjustable time out
- Remove battery and recharge
- Available with optional additional battery
- Available with optional high gain antenna---allows more precise targeting of the radio
DIGITAL WIRELESS TRANSMISSIONDIGITAL is MUCH higher quality video than analog ---with minimal interference
LONG TRANSMISSION RANGEUp to 300' (100m) indoors
INEXPENSIVESurprisingly affordable for any application
APPLICATIONSForklifts and Cranes:Camera/battery on backrest or boom
Turn on/off camera from below
Operator views load--forks or hook
Construction Equipment---TrucksUsed as remote back up camera
Triggers can automatically initiate
proper remote camera to come on
Remote SurveillanceSmall battery powered camera
allows quickset up for remote view
For more KEYTROLLER product information
www.keytroller.com For more information view website: www.keytroller.com or contact KEYTROLLER, LLC. 813-877-4500 or email: send a message
