EP launches CPD10ET Electric Forklift
- 17 Jan 2013 ( #599 )
The new and revolutionary EP 1Ton electric forklift is the only one of its kind designed for use on industrial floors. The unique vehicle which is with less than 2m high and weighing 1.8t can be customised and deployed in industrial elevators.
The EP CPD10ET Electric Forklift features:
Characteristics
  1. Equipped with world-class hydraulic power pack, transmission case and electric control system, the vehicle is responsive, with accurate controls and excellent power efficiency.
  2. The innovative and maintenance-free AC system ensures a longer battery service life.
  3. Imported AC electronic control steering system ensures comfortable, low-noise operation.
  4. ZAPI walking motor controller and Bucher oil pump motor guarantee the stability and manouvreability when lifting, lowering and walking.
  5. Comfortable and safe seat reduces the strain on the operator.
Operability & Safety
  1. The steering wheel, dashboard and power switch have compact design for operator convenience.
  2. New compact mast design reduces the height of the vehicle to 2 meters, while the front overhang and overall length are decreased, which greatly reduces the limitation of the work space.
  3. The handrail platform on the right side can be adjusted to the suitable height of the operators.
  4. Electromagnetic Valve lifting system improves safety when operating.
  5. Electromagnetic parking brake provides braking during deceleration.
  6. Emergency plug is mounted right behind the handrail, all power can be cut off by simply pulling emergency plug and the truck stops immediately.
  7. The safeguard is made of specially designed tubular product which is safe and stylish.
  8. One-piece welding technique is used in the cover board of the battery and frame, ensuring rigidity of whole vehicle body.
Maintenance & Serviceability
  1. Top quality American AMP connectors prevent moisture and contaminants from interrupting truck operation in all environments.
  2. Driving motor, pump motor and brake pedal are cleverly arranged, and the oil pipeline is also optimised, while the foot petal is easy to remove. All these make it convenient for checking, maintenance and replacing components.
  3. The intelligent programmable LCD displays fault codes, alerting the operator and service engineer to any problems and helping engineers to solve the problem quickly.
  4. AC driving motor and AC pump motor are brushless, of high stability and excellent performance, reducing maintenance time and cost greatly.
  5. The back door design is convenient for clearing, checking and maintenance.
  6. Sideway battery and roller-bearing battery box design make it easy for the operator to replace the battery.
  7. Brake oil cup is arranged right above the brake, convenient for checking and brake oil addition.
Options
  1. Battery
  2. Mast type
  3. Sideshift
EP Equipment is a world leader in the manufacture of materials handling equipment and associated components. EP has built a worldwide sales network in more than 40 countries across the globe, with associate companies in the United States, Europe, Canada, Japan and Korea. In 2008, DHF Intralogistik ranked EP the 24th largest materials handling manufacturer in the world, and EP has continued to grow by over 50% per annum ever since. EP is engaged in an ongoing effort to expand, innovate, and deliver exceptional material handling products and solutions. Let's grow together.
Full contact details:
EP EQUIPMENT CO., LTD.
EMAIL: send us an email
WEB: www.ep-ep.com
TEL: 86-571-28035657/28035633
FAX: 86-571-28035665
Click here to visit our shopfront
