Productivity, flexibility, safety with Bolzoni Auramo push pulls
- 13 Dec 2012 ( #595 )
Click here to view the
Click here to view the "Easy Rider"
Forklift attachment manufacturer Bolzoni Auramo has a complete range of Push Pulls. These attachments, specifically designed to handle goods with slipsheets instead of wooden pallets, are used in various industries such as food, beverage, glassware, building material, agricultural, paper, chemical and automotive parts industry.
The range includes the Dedicated Push Pull, for customers using exclusively slipsheeted loads and the Fork-Mounted Easy Rider Push Pull. Thanks to an extremely quick and effective new fitting system, the "EASY RIDER" offers the
possibility to convert a conventional fork lift truck with forks into a specially equipped machine to handle loads on slip sheets. Increasing productivity without any compromise for safety.
The Bolzoni Auramo proposal is completed by the Mark 55 Push Pull, specifically developed to suit the needs of the American market and suitable for handling both slipsheeted loads and pallets.
Some special features allow this range to be the solution to the most various handling needs:
  • Wide windows in the push plate and gripper jaw allows for excellent visibility in both retracted and extended positions when clamping the slip-sheet.
  • 4 degrees tilting faceplate, when fully extended, helps prevent any damage to the product.
  • Chamfered platen corners prevent tears in the slipsheet and damage to the product.
  • Pressure relief valve guarantees structure and load protection.
  • Gripper jaw is actuated by two cylinders, assuring a perfect force distribution on the clamping bar to help eliminating any damage to the slipsheet.
  • Hydraulic system protected with steel cover and plastic wire wrapper.
  • The vertical position of the pad is adjustable should the pad becomes worn or damaged, resulting in less maintenance costs.
  • Rubber-surfaced gripper bar for better slipsheet clamping.
  • Pantograph actuated by two cylinders for better distribution of pushing and pulling forces. Grease fittings in pantograph mechanism group.
  • Platens manufactured in high tensile steel, for stronger and thinner structure.
  • Noiseless handling thanks to design optimization and end stroke shock absorber.
Bolzoni Auramo is a market leader in the production of forklift truck attachments, forks and lift tables. The company has manufacturing plants in Italy, Germany, Finland, America and China and through its network of direct branches and independent dealers covering all continents, it is able to satisfy all market requirements.
World leader in the market of OEM factory installed products, Bolzoni Auramo is approved supplier for all main fork lift truck manufacturers.
For more information on the Bolzoni Auramo products please visit our Website
www.bolzoni-auramo.com and contact us at info@bolzoni-auramo.com, or
contact the nearest Bolzoni Auramo representative.
Click to view the Bolzoni Auramo ShopFront
