RUYI - Electric Pallet Truck and Full Electric Stacker
- 16 Aug 2012 ( #578 )
Electric Pallet Truck - Model: CBD20R-II
Model: CBD20R-II
Model: CBD20R-II
Advantages:
SAFETY AND EFFICIENCY
  • Power steering system (EPS) makes steering operation easy, flexible and safer.
  • Muti-function display shows battery status, hour meter, fault code, slow running state, etc.
  • High-capacity battery (240Ah) and high-power Drive Motor provide superior power and ensure lasting runtime.
  • The control system uses efficient micro-computer MOS, drive motor is an AC adjustable-speed motor which provides long life and good speed adjusting performance, while remaining maintenance-free.
  • AC motor eliminates carbon brushes and has good starting performance on ramps.
  • The side door of battery opens conveniently. Once the locking mechanism is loosened, it is very easy to pull the battery unit out from the side.
  • Tiller heads are imported from Germany, providing safer operation.
  • Built-in pressure relief valve protects the truck from overloads, and increases the truck's reliability.
  • Braking applied with handle in upright and horizontal position, increasing the truck's safety.
  • Emergency power disconnector.
  • Turtle-shaped low speed switch.
  • Stepless speed control.
STRUCTRAL
  • Standing drive motor system makes the replacement and maintenance of the driving wheels easy and convenient.
  • Combined balance wheels increase steadiness, preventing the truck from being rocked from side to side.
  • The balance wheel is detachable, and is convenient to maintain.
EASY MAINTENANCE
  • Low battery protection setting prolongs the battery use time.
  • CANbus technology reduces wiring complexity, making the line clear, orderly and easy to repair and also increases the truck's reliability.
  • Hall-effect throttle control eliminates component wear and prolongs its use time.
  • With clever design, the cover is reliable and easy to dismantle, which makes the maintenance of the electrical parts very easy.
Full Electric Stacker - Model: CDDK15-II
Model: CDDK15-Ⅱ
Model: CDDK15-Ⅱ
Advantages:
OPTIMUM STRUCTURAL DESIGN:
  • Low center of the gravity ensures the stable operation.
  • Vertical drive wheel ensures convenience for maintenance while also ensuring a small turning radius. The structure of motor is water-proof and dust-proof, which makes the braking and motor more durable and reliable.
  • The mast and the frame are dividable and exchangeable.
  • Full free lifting, fit for working under low ceilings. (The lifting height is 3 metres, and the truck can enter into a 2-metre high door)
SERVICEABILITY:
  • The electronic components' concentrated design simplifies the circuit and provides easy access to assemble, debug and maintain.
  • CANbus technology reduces wiring complexity and increase reliability.
  • Hall element reduces wear components, resulting in increased component life.
Mr. Chu Jiang
Vice President
Tel: +86-571-87153626, 87153634
Fax: +86-571-87153628, 87153638
Email: ruyi@mail.hz.zj.cn / sales@liftool.com
Web: www.xilin.com
Click here to view the RUYI ShopFront
+86 574... Show
656 North Taoyuan Road
Ninghai, Zhejiang 315600
China
