Maximal New “A” Series Forklift Designed for the driver
- 22 Mar 2012 ( #557 )
What is the "A" Series?
Maximal's first series was the "M" series forklift, the first letter of "MAXIMAL". So "A" is the second.
Design concept
Maximal's New "A" Series Forklift is designed for the driver. Maximal engineers have focused on improving the comfort and safety for new series forklifts, with lower noise levels, less vibration, more safety, and every small detail carefully designed prepared for the driver.
Main points of the New "A" series Forklift
Comfort
  • Full floating safeguard/cabin system, with new engine vibration damper;
  • Generous space for the driver with expanded foot room to reduce fatigue and increase comfort;
  • Special muffler and new noise isolation material, reducing noise levels by more than 4DB;
  • Suspension foot brake allows more room and comfort for driver's feet;
  • Foot-operated parking brake device greatly reduces fatigue in the left arm;
  • Convenient adjusting steering wheel increases angle to 8°;
  • Maximal special display with blue backlight LED for driver convenience and ease of information viewing;
  • Integrated plastic cover of instrument frame for neat and fashionable appearance, with extra storage space for the driver;
    • Full suspension transmission system is available as an option. A new floating type aluminum alloy hydraulic transmission achieves excellent performance and accommodates heavy loading conditions. Suspension transmission replaces traditional rigid connections, greatly improving the forklift's vibration and noise;
    • Mini-level system is available as an option.
Safety
  • Wide view mast, with visibility increased from 690mm to 720mm to enhance the operator's view and safety.
  • The centre of gravity is reduced 50mm from the M series, increasing stability of the truck and offering more visibility at the rear.
  • High strength safe guard/cabin by profiled steel insert all around keep you safer, with a high-strength organic glass ceiling as standard
  • This forklift is built with a high-safety wire harness, while adopting waterproof AMP connectors and waterproof/shake-proof instruments, both of which comply with stringent safety standards.
  • Equipped with engine protective net as standard
    • OPS system is available for customers as an optional extra.
Reliability & Exchangeability
  • The composite roller structure has been improved for enhanced reliability.
  • Cabin can be installed directly on the standard safeguard, which is very convenient for the customer to put on and off the cabin
  • Engine cover, instrument panel, display, safeguard and most of the operation components are exchangeable between 1- Mini 4ton forklifts
Energy saving and environmental protection
  • New dynamic load-sensing hydraulic steering system improves work efficiency and energy conservation, with fuel consumption reduced by 8%.
  • With more environmentally-aware design, the new forklift is totally asbestos-free and most of the components are recyclable.
Maximal's New "A" series forklift will be on the market in August 2012, and we look forward to your continued interest in our products.
Contact information:
Zhejiang Maximal Forklift Co., Ltd.
E-mail: info@maxforklift.com
Web: www.maxforklift.com
Phone:
+86-571-28001567
Fax: +86-571-28001569
For more company and product information click here to visit the MAXIMAL Shopfront
