RUYI CDDR15/CDDR15Z Series Full Electric Stacker
- 29 Sep 2011 ( #533 )
Click for larger image.
Ningbo Ruyi Joint Stock Co., Ltd. introduces the new CDDR15/CDDR15Z Series Full Electric Stacker equipped with design features to ensure safety, productivity and serviceability.
SAFETY AND PRODUCTIVITY
  • The mast is individually attached to the truck. The user can change the mast for specific needs.
  • Advanced AC control system with intelligent regenerative brake system increases overall truck performance by decreasing battery charge intervals.
  • Multi-function display shows battery status, hour meter, fault code, etc.
  • Damping cushion for low-noise operation.
  • Emergency reversing device.
  • Auto-deceleration system utilises regenerative braking, which significantly reduces brake wear and improves operating safety.
  • Built-in pressure relief valve protects the trucks from overloads.
  • Braking can be applied with handle upright or in horizontal position.
  • Emergency power disconnection.
  • Low speed select switch in the handle.
  • Stepless speed control.
  • With lifting, limit switch shuts off pump motor at the max lifting height.
STRUCTURAL
  • Low center of gravity ensures the stable operation.
  • Standing drive motor system has a small turning radius and is easy to maintain. The motor structure is water-proof and dust-proof.
  • One-piece gauge steel is formed for maximum fork strength.
  • Steel for the mast imported from Germany.
SERVICEABILITY
  • The electronic components' concentrated design simplifies the circuit and makes easy access to repair and maintain.
  • CANbus technology reduces wiring complexity and increases reliability.
  • Advanced AC control system with brushless motor and directional contactors require minimal maintenance.
  • Auto-deceleration system utilises regenerative braking which significantly reduces brake wear and makes the operation safer.
  • Side-mounted battery with roll-out system is very convenient for replacement. Also, a top battery cover makes filling much easier.
Mr. Chu Jiang
Vice President
Tel: +86-571-87153626, 87153634
Fax: +86-571-87153628, 87153638
Email: ruyi@mail.hz.zj.cn, sales@liftool.com
Web: www.xilin.com
Or; Click to view the RUYI ShopFront
+86 574... Show
656 North Taoyuan Road
Ninghai, Zhejiang 315600
China
