Keytroller's START SMART RFID ignition system - reliable, simple, tough
- 22 Mar 2012 ( #557 )
KEYTROLLER's START SMART is a simple, highly reliable, easy to install keypad ignition system designed to tough outdoor usage. The system is available as a code only or HID--RFID card enabled models. Inexpensive system fits to any make or model forklift, internal combustion or electric. Designed to eliminate keys, keep untrained and unauthorized operators off, and monitor usage. Because of it's small (3" X 3.5") size and no exposed cables, the device is frequently used on pallet jacks and personnel carriers where more elaborate access monitoring systems can not be justified.
SSD-215 Second generation unit has the following features:
  • New "low profile" design has NO exposed cables
    and installs easily to any dashboard
    (3.5" W X 3" H X 3/4" D)
  • Code input enables device (4-6 digit codes
    acceptable)
  • HID type RFID card reader model allows for both code or RFID enabling--use company ID card to enable device
  • Start/Stop vehicle (engine or electric) directly from keypad - NO KEYS!
  • Designed for harsh outdoor conditions--sealed and potted internally for extreme environments
  • USB port allows for programming users and expiration dates and downloading event usage logs
  • Wired relay connects to vehicle ignition switch (3 wires on IC; 2 wires on EL)
  • Installs in minutes to any diesel, gas, LPG or electric machine
  • Has programmable ignition delay to charge Glow Plug circuit for Diesel applications
  • Electric vehicle starts immediately after entering
    code or flashing RFID card
  • All electronics are sealed internally for tough, abusive outdoor applications-- Waterproof and vandal proof IP67
  • High reliability for the toughest applications and toughest equipment
  • Programmed w/ programmer's code from keypad or from PC--accepts up to 4000 users with expiration dates
  • Programmer or supervisor code can temporarily lock out users
  • Can be programmed to require 2 finger start, requiring both START keys be pushed simultaneously to start engine.
  • When connected to seat switch, device will "time out" and shut off unit and engine in programmable # minutes
  • Allows review of usage log for usage time by machine or operator and start--stop times
  • Training can be scheduled in conjunction with expiration date of user code/card
2 Auxiliary inputs:
  • Enabled by programmer on keypad or enabled from PC (default is disabled)
  • Connected to either:
       -Seat switch
       -Seat belt switch
       -Overload sensor
       -Low oil or Hi Temp input
  • When these connected inputs go "high", START-SMART will shut ignition down in programmable # minutes of continuous signal
Dealer cost: $365 (code only) and $465 (HID-RFID). Kits include relay module.
For more information view website: www.keytroller.com or contact KEYTROLLER, LLC. 813-877-4500 or email: info@keytroller.com
Click here to visit the KEYTROLLER ShopFront
