Handle more pallets at once with e-l-m’s multi pallet handlers
- 11 Nov 2010 ( #487 )
Handle more pallets at once with e-l-m's multi pallet handlers
e-l-m has made it possible for your truck to move more pallets at the same time. By choosing a multi pallet handler from e-l-m, you can move up to 4 pallets at the same time - a good investment if you want to cut back on operating costs.
Move up to 4 pallets at the same time
In the product category multi pallet handlers, there are 3 types of attachments in e-l-m's program: 1 or 2 Pallet Handler type DPK-C, 2 or 4 Pallet Handler type DPK-C, and 1, 2 or 3 Pallet Handler type DRPK-C. This means that you can choose the attachment, which suits the number of pallets you have to move the best.
Robust construction for safe transport
The multi pallet handlers all have a strong construction of the frame, which minimises unsafe transport and makes work related injuries less likely. The strong construction of the frame also increases the speed of the transport, thereby improving efficiency considerably as you cannot just move the pallets faster, but also move more pallets at the same time. Furthermore, all multi pallet handlers produce a good view for the driver, which gives him/her a better overview of the load, and making the transport safer.
Low operating costs
All 3 types of multi pallet handlers are delivered with a sideshift as standard, which eases the truck driver's work and ensures precise placement of the pallets. Also, the construction of the frame is very robust, so the attachment has a long lifespan, and a minimum of maintenance as the consumption of wear parts is small.
Interested? For more company and product information go to www.e-l-m.com, or visit the e-l-m ShopFront.
