Smarter Speed Control at Height: Xilin’s Answer to Safer Order Picking
- 3 Jul 2025 ( #1237 )
As warehouses adopt higher racks and faster fulfillment, working at height poses greater risks and demands higher precision. Xilin’s Electric High-Level Order Picker meets these challenges with intelligent deceleration that enhances safety, durability, and picking accuracy.
Smart Speed Control for Safer High-Level Operations
When the fork or platform rises above 3 meters, vehicle stability decreases. The high-level automatic deceleration function monitors lift height in real time. Once the threshold is reached, it reduces travel speed by 30%–50% using a progressive algorithm.
This smart system adjusts the deceleration curve based on load conditions, applying stricter speed limits under heavy loads. It effectively prevents sway, cuts rollover risk by over 60%, and ensures safer operation at height.
Extending Equipment Life Through Intelligent Control
The deceleration function integrates with the vehicle controller via CAN bus, reducing speed while optimizing hydraulic pressure and motor torque under elevated conditions.
This coordinated control cuts dynamic load on key parts by over 40%, extending gantry life by 2–3 years and reducing annual maintenance costs by up to 20%.
High-Accuracy Picking at Elevated Heights
In high-level picking, operational accuracy is key to storage efficiency. The automatic deceleration function uses multi-stage speed control—slowing down 1.5–2 meters before the target and fine-tuning within 0.5 meters.
This approach boosts positioning accuracy to ±10 mm, over 50% better than traditional equipment, enabling smoother, more efficient picking.
Certified Safety Meets Global Standards
The automatic deceleration function meets OSHA, ANSI, and CE standards, and its control algorithm is TÜV-certified to SIL2 safety level. A redundant system architecture ensures reliable performance in all conditions.
It also records the last 1,000 deceleration events, providing valuable data for safety audits and incident analysis.
Xilin’s Electric High-Level Order Picker combines intelligent technology with proven performance, helping you lift smarter, safer, and longer.
Contact us today to learn how we can support your warehouse’s elevated needs.
+86 574... Show
656 North Taoyuan Road
Ninghai, Zhejiang 315600
China
